Reply 1 of 1, by bloodem
bloodem
Offline
- Oldbie
Technically it probably wouldn't be necessary in a case with good airflow, however these cards are so expensive nowadays that adding a fan is just sheer common sense 😀
I recommend adding a two-fan case bracket under the video card instead of modding it.
The PCI Voodoo 3 on the other hand ABSOLUTELY needs fans, for both the GPU but especially for the voltage regulator.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
