First post, by ael1964
I have an AMD ATHLON XP 2400 with 1 GB RAM,200 GB HD SB AUDIGY and GEFORCE 5700 LE.In some games I have a problem with their speed such as Need For Speed SE and Grabriel Knight CD version,I`m using at dosconf,640x480 fullfixed resoulution,double buffer,normal core and 13000 cycles.I also use scaler=advinterp2x,on some games I have problem with the speed...And I can`t find the appropriate number of cycles what to do?Most of them are cdrom games....When I use dynamic core I don`t see any difference...
Give back our child memories....!DOS games for ever!
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
There is nothing much anyone can tell you (if you read DOSBOX Guides/WIKI as far as running resource demanding games/speeding up DOSBOX !!!).
You are hitting limits of your hardware. Do not use scalers. Dynamic core enables to achieve more cycles without sound skipping. Everything is in documentation.
Closing. Basically I do not think these types of questions have any sense ...
Mirek
