First post, by retrogamerguy1997
I am unable to install Drivers for Sound Blaster Live CT4780. I've tried to install the drivers linked in the VCF forums and MSFN forums and both of them lock up Windows and upon reboot show a code 11 error for the card but not the joystick port
EDIT: The ones on philscomputerlab crash as well
EDIT2: Solved the issue by moving the card to another PCI slot.
EDIT3: the issue has returned
EDIT 4/15/2021: I consider the matter closed as I ordered a sound card from ebay.
Reply 2 of 29, by cyclone3d
What are the specs of the rest of the system?
What OS and what updates have you installed?
Do you have the chipset drivers installed?
Do you have the latest BIOS for the motherboard?
The original install CD should be available on vogonsdrivers.com
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 29, by retrogamerguy1997
cyclone3d wrote on 2021-04-14, 01:44:
What are the specs of the rest of the system? […]
Specs are in this thread: Just built a Pentium 2 system in 2021
OS is Windows 98SE
Yes, i have the chipset drivers
No, I do not have the latest BIOS
And I just got done testing the card in another PC, a Pentium 4 and the system froze completely on xp installing the included drivers. So maybe there is something wrong with the card?
Reply 4 of 29, by cyclone3d
Yeah, probably something wrong with that card.
Look at it under a magnifying glass and make sure no chips have pins bent and touching each other.
Might also want to try cleaning the edge connector with a pencil eraser to remove the oxidation... Or deoxit if you have that.
YMF7x4 Guide
Reply 5 of 29, by retrogamerguy1997
The only thing out of the ordinary I see is what looks like a tumor growing out of the silvery looking part on the card. one of the capacitors was bent but bending it back up straight didn't fix the issue.
    431.94 KiB
Reply 6 of 29, by Imperious
retrogamerguy1997 wrote on 2021-04-14, 12:08:
That "silvery part" is the crystal oscillator and the "tumour" is just a solder blob that I assume is grounding the case.
Reply 7 of 29, by weedeewee
That capacitor that was bent could still be fine, though it might also just be dry and not doing anything anymore.
Worst case it was shorted and just caused the computer not to boot, though a slight current spike might have burnt out the short, causing the computer to boot the next time.
Just some possibilities 😀
Do not ask Why !
Reply 8 of 29, by retrogamerguy1997
weedeewee wrote on 2021-04-14, 13:57:
I don't know anything about circuitry and electric stuff. It never stopped the computer from booting, just that it hangs when windows is installing the drivers. no matter which drivers I use or even switching computers.
Reply 9 of 29, by retrogamerguy1997
I just really need to know if the card is dead or not, and if so what are my options
Reply 10 of 29, by weedeewee
have you tried a linux live dist ? in multiple computers ?
If that hangs on the soundcard... well... I'ld guess it's broken.
Do not ask Why !
Reply 11 of 29, by retrogamerguy1997
weedeewee wrote on 2021-04-15, 11:12:
I don't know what linux distro would support the card and work on a pentium 2?
Reply 13 of 29, by weedeewee
at this point I'm wondering if maybe the eeprom on the card is broken, has bad data, or the card is just borked.
Do not ask Why !
Reply 14 of 29, by retrogamerguy1997
if that's the case, then I might as well start looking for other cards on ebay. There's a listing for the AOPEN AW744L II but I don't know what the "no GSP" in the title means. It's a tiny bit more than I want to spend on a sound card, but philscomputerlab says it's a good card. then again, it depends on the motherboard chipset (my motherboard has the 440BX).
Reply 15 of 29, by weedeewee
Well there is this site https://www.ixbt.com/multimedia/live-to-live51.shtml in russian and this one https://damsbo.com/Soundblaster/sbmod.htm
You might give it a crack.
I think you can't make it any worse 😀
Do not ask Why !
Reply 16 of 29, by retrogamerguy1997
weedeewee wrote on 2021-04-15, 12:04:
I don't know anything about soldering nor do i have the equipment.
Reply 17 of 29, by weedeewee
There is mention of using a wpcrset program... which means no (un)soldering required. Though it seems as if it wasn't tested. YMMV.
good luck.
https://www.damsbo.com/Soundblaster/wpcrs120.zip
edit: meh nevermind
Do not ask Why !
Reply 18 of 29, by Pierre32
retrogamerguy1997 wrote on 2021-04-15, 11:54:
I bought one of these from the same seller, and it's very much worth it. There are drivers to try with different chipsets if you have issues with the main ones:
https://www.philscomputerlab.com/yamaha-ymf74 … sound-card.html
The "no GSP" just means that listing doesn't use ebay's Global Shipping Program. He usually offers listings with an alternate shipping option for those who prefer it, but he only has the one listing up currently.
