First post, by treeman
I just built a socket 7 system, pentium 233 mmx with the motherboard 586tx3
everything works but the power led on my case pulsates when the system is powered off.
When I power it on the green led is on steady, once I turn it off with the power button system shuts off but the green led pulses.
If I remove the cable from the psu it stops.
The led cable is plugged right, I checked it. The Hard disk light works fine and is off when powered off so its only the led light.
Could this be a leak somewhere or a semi short? I never had this happen, anybody have a similar experience?
Reply 1 of 2, by PC Hoarder Patrol
Seems OK if you're using an ATX PSU
From the manual (P20) - "Power LED will be flashed once per second when system Get into Soft-off mode (ATX PWR only)."
Reply 2 of 2, by treeman
ah thanx for that, yeah it is a atx psu. Never seen this before but since its normal then ok
