First post, by seanneko
I recently picked up a pile of old parts which included this 5.25" tape drive. It came with a few 40MB mini cassettes.
I assume it needs a special controller card which unfortunately I don't have. Does anyone know anything about it and how I could get it working? What sort of interface does it use? Even just a brand or model number would be helpful.
1.91 MiB
Reply 1 of 8, by weedeewee
I was gonna say it's a floppy interface, but then I noticed the extension... So maybe it isn't....
More photos would probably make it easier to identify.
All I got for now is https://en.wikipedia.org/wiki/Quarter-i ... ridge_(MC) which would indicate it actually is a floppy interface.
Do not ask Why !
Reply 2 of 8, by seanneko
True, it wasn't the most helpful photo. Here are a couple more.
1.28 MiB
940.63 KiB
The larger connector is the same as a regular 5.25 floppy drive, with the same notch and everything. The other connector is obviously something different though.
I thought it may have been an MFM interface but after counting the number of pins I don't think it matches.
Reply 4 of 8, by weedeewee
the eprom seems to have seen better days, piece of a corner missing...
Do not ask Why !
Reply 5 of 8, by seanneko
Miphee wrote on 2021-04-15, 10:58:
Great, sounds like exactly what it is.
It says it uses a "standard minifloppy interface". I'm assuming that's just a regular floppy interface that any computer has. How is it able to read/write 40MB of data from what presents itself as a floppy drive? Is it all just trickery done in software?
Reply 7 of 8, by weedeewee
I guess it no longer has an id sticker visible when looked at from the connector side ?
Do not ask Why !
Reply 8 of 8, by seanneko
Thanks for finding the user manual. I won't have time to even plug it in for at least a few days but I'll definitely come back to it and try to get it working.
weedeewee wrote on 2021-04-15, 11:10:
Lol... Ok I'm totally blind. It does have a sticker there which says it's an Irwin model 145. No idea how I didn't see that there until now.
