First post, by VikingCynic
I've recently acquired working Memorex Telex Intelligent Systems Model 8067. It's a 368 PGA board. I dropped a AMD386 DX40 into it and it fires right up. Unfortunately, the bus speed appears to be set at 25 MHz. There's a 10 position DIP switch and a set of 3 jumpers next to it but no markings on the board what so ever that would indicate how to configure them. I've been unsuccessful so far in locating any information on it.
If anyone has encountered this board or might have a line on where a manual could be found I would greatly appreciate any information. The board is quite nice and I'd like to see if it's possible to kick the bus up to 40 MHz to take full advantage of the CPU I have.
Thanks!
Reply 1 of 1, by Horun
Can you post some pictures ?
Here is some history about Memorex Telex from 1996 that is interesting read.... https://tulsaworld.com/archive/flood-of-chang … bab722f342.html
Interesting note from Wiki is that Tandy owned them for a while too !
