Processor Clarification
First post, by Tyrant
Hi all,
I've just updated my BIOS so it can accept better processors (motherboard is ASUS P4B-M) and from the information on ASUS' website the best processors for my motherboard are one of these;
Intel Pentium 4 P4 2.6GHz 512KB 400MHz Socket 478 SL6PP
Intel Pentium 4 P4 2.6GHz 512KB 800MHz Socket 478 SL6WH
Intel Pentium 4 P4 2.8 GHz 512KB 400MHz Socket 478 SL7EY
I tried the 2.8ghz and it didn't work, I'm not sure if that's because it was a dud but I'm going to try one of the first two instead. Someone said something about the 400MHZ being better because the 800MHZ never works as advertised. Can someone elaborate on this? Thanks
Reply 1 of 10, by flupke11
Knowing which mainboard you have, might help. I've got an inkling it might be a 400 FSB board.
Reply 2 of 10, by Tyrant
flupke11 wrote on 2021-04-22, 07:15:
Apologies you're right, as soon as you said that I checked the manual and it does mention 400MHZ bus speed. It's a P4B-M, it could just be referring to bus speed of the processor that comes with it but I'm pretty sure it isn't.
Reply 3 of 10, by flupke11
I suppose you are still battling the P4B, if I read through your older posts.
I explained 800FSB cou's will not work, they're not designed to work on this board and they are not listed on Asus' list. For this board you need 400FSB CPU's. Two you listed should work from Bios version 1007 onwards.
The Front Side Bus speed is the speed (in MHz) between the CPU, the North Bridge and the memory. The North Bridge is the housekeeper chip on your mainboard, which takes care of interconnecting the CPU with the memory, and all peripherals (graphics card , USB, etc). Your North Bridge is the Intel 845 chip, only allowing CPU' with an FSB of 400 MHz, which is in fact 4*100 MHz.
The internal clock speed of the CPU is a multiplication of the base FSB (100MHz) times the internal multiplier of the CPU (24) which gives you the advertised speed of the CPU (2400 MHz or 2,4 GHz).
Reply 4 of 10, by Tyrant
flupke11 wrote on 2021-04-22, 07:31:
I suppose you are still battling the P4B, if I read through your older posts. […]
Right that's making more sense now. I don't see where you found 1007? I'm only seeing up to 1006.005 but I installed 1005 just because the newer one being beta sounds a little iffy to me. Thought I'd start at 1005 and see if it works.
Reply 5 of 10, by flupke11
You shouldn't worry too much about Betas on the Asus site. I usually flash the latest available, beta or not.
The 1007 was on the P4B page, not the P4B-M. So you can disregard that comment of mine.
Reply 6 of 10, by Tyrant
flupke11 wrote on 2021-04-22, 07:48:
Alright thanks for the help, I'll let you know how the SL6PP goes when it arrives.
Reply 7 of 10, by zyga64
Acording to this review https://m.hexus.net/tech/reviews/mainboard/242-asus-p4b/, Asus P4B (full ATX) being its big brother based on the same chipset, worked just fine with 533MHz Northwood.
So you may give it a try.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 8 of 10, by Tyrant
zyga64 wrote on 2021-04-22, 09:52:
I don't think it will work man, as flupke11 explained the "North Bridge is the Intel 845 chip, only allowing CPU' with an FSB of 400 MHz, which is in fact 4*100 MHz."
Reply 10 of 10, by zyga64
Same for mentioned P4B https://www.asus.com/supportonly/P4B/HelpDesk_CPU/ (only 400MHz).
But it may work when overclocking chipset. I'm not saying that it will work for sure.
Asrock for example promised 1066FSB on i865 (officially max 800MHz) - ConRoe865PE, 775i65G. It's nothing unusual...
Anyway, it will be throttled by SDR SDRAM memory...
