First post, by matze79
Hi,
i build a Pentium 60 1-2 Years ago and did not use it very often,
but i noticed Strange Problems with Soundblaster 16, 32 and AWE64.
Each one is making a Crackling Noise when Playing Mod Files with GLX and Terminal Velocity has Strange Sound too.
All Cards are working fine in other Machines.
Playing Mod Files with MOD Master does work fine.
So it seems something is wrong with 16bit Playback ?
Also Adlib Sound and most 8Bit SB Sound Titles working Fine.
DMA is conflict Free, and IO Addresses too.
It somehow remembers me of UM8810PAIO Soundblaster Issues if wrong BIOS Version is used.
Anyone run this issue ? changing ISA Speed to compatibility, disabling LPT etc did not Help
also removed every Card except for VGA and Soundcard.
Thanks
Matthias
Reply 2 of 13, by matze79
Hm, behind Paywall
GLX
The attachment modmaster.mp3 is no longer available
(Crackling)
Terminal Velocity:
The attachment TV.mp3 is no longer available
(High Pitch Noise)
Reply 4 of 13, by chrismeyer6
Just kinda taking a shot here but does your power supply have a -12 volt line and if it does is it in spec?
Reply 5 of 13, by pyrogx
Sounds like you're trying to use SB16 in SBPro stereo mode. This doesn't work properly, SB16 is not compatible to SBPro stereo mode.
Reply 6 of 13, by matze79
Anyway got around it, put SB in a Bin and use ESS1869 with X2GS now.
Reply 8 of 13, by matze79
I have Elsa Winner with S3 86C375 and 4Mb
Reply 10 of 13, by matze79
Does not help at all.
Reply 11 of 13, by chrismeyer6
Long shot but does your sound card need a -5volt line and does your power supply have -5volts?
Reply 12 of 13, by matze79
No, it does not have -5V and its also not needed.
I run no Card that requires -5V.
Missing -5V with Card needing it would cause Weird Sound in all Titles, not only a few specific ones.
Reply 13 of 13, by matze79
The issue really was the PSU, it had ripple current.
The Soundblaster did not like this.
I replaced some caps inside the Enermax PSU and it works again.
