First post, by appiah4
- l33t++
Anyone know of STLs out there for attaching heatsinks to 486 CPUs?
Nope but one time used Permatex "RED" hi-temp gasket maker to attach aluminum HS to a 486, worked great and still attached 10 years later. Just cleaned everything with alcohol, used HS compound in middle of HS and put very small ball of Permatex on the corners of the cpu. Press on and put a little weight on it, let it dry overnite.
Not the perfect solution but a better alternative to adhesive pads, etc imho
Sadly no. But IEC has NOS clip-on 486 HSF in stock for $8. I just ordered one last week
these are the only two i saw online
https://www.thingiverse.com/thing:2459258
https://www.thingiverse.com/thing:4659201
but i dont like because you need a heatsink of an specific height.
you can update the design tho, but im not sure what can be modified in order to make it for a customized heatsink.
maxtherabbit wrote on 2021-04-27, 23:09:Sadly no. But IEC has NOS clip-on 486 HSF in stock for $8. I just ordered one last week
IEC?
Cheers,
Great Northern aka Canada.
Thanks !
pentiumspeed wrote on 2021-04-28, 00:04:IEC?
Cheers,
check yer Inbox
Horun wrote on 2021-04-28, 01:07:check yer Inbox
Please indulge me as well 😀
SETBLASTER wrote on 2021-04-27, 23:37:these are the only two i saw online
First one looks like it will do the job for me, thanks!
