First post, by PcBytes
- l33t
As the title suggests, I have an issue with a VIA MVP3 based machine I have built.
First off, here are the specs:
LuckyTech P5MVP3-99x (w/ patched BIOS)
80GB Seagate Barracuda 7200.9 HDD (PATA)
TSSTCorp SH-S182D DVD-RW
3Dfx Voodoo 3 3000 16MB AGP2x
Sound Blaster Live 5.1 CT4830
NEC USB2.0 PCI card
Windows 98 SE w/ NUSB3.3 and VIA 4in1 v4.35
Now onto the problem - regardless if I reinstall Windows or reinstall drivers, I ALWAYS get an Code 10 error on the Secondary IDE channel driver. It only shows up on the Secondary channel, as it seems the Primary IDE channel will show up as working fine. As a side effect of the Code 10 issue, I also have no optical drive showing up in My Computer at all.
Any ideas what can I try? IIRC there was a NOIDE registry trick that would fix this, but on my install, NOIDE does not exist.
