Reliving my 486 Days...
First post, by benjibarnicals
Hey all,
Firstly, great to be here, have used Vogons for years on various machines from the late 90's era for some useful knowledge but, this is now my first main foray into slightly older hardware which I do actually need some advice for (a time before PnP, BIOS auto detection etc).
I very luckily was able to get hold of my first ever PC (back in '92), which was a Viglen Genie Professional 486-DX2/66. It came 16Mb Ram, original PSU last test date 2/2/93, motherboard (DT-LB2AL) etc but with two hard drives (both not original), one was from 1999 which was completely broken (head knocking), the remaining drive, a Seagate ST51080A 1GB that had its sector bios upgraded with EZ-Drive to allow it to be seen as a full 1Gb (not the 504Mb limit by the BIOS), the floppy drive was broken so I've replaced this and various other little bits...
Anyway, It also came with a few ISA cards installed; namely an SB16 Value (CT2770), US Robotics Sportster 33600 Modem, Additional dual game port card and a Logitech Scanner Controller Board (not needed for me now).
I'm doing fine getting things running, DOS 6.22 is on (though I'm playing around with the boot sequence at the moment, Windows 3.11 WfW will be going on soon). However, I would like a little guidance on Drivers/Software for use in Windows 3x, certainly for the sound card, I had a look through the VogosDriver site but I want to be sure what would be the best download from here for drives for this CT2770 card for DOS and for Windows 3x, if there was software to go long with this (from Creative) that would be a bonus. Then next would be any software/drivers for the modem, and perhaps if anything is needed for the mother board.
I know theres a lot here and I'm just hoping for a little guidance to kick start this machine. Oh, a few pics attached, more to follow...
Thank you all!
Ben
Reply 1 of 9, by Disruptor
Welcome Ben.
Feel lucky when you have a 486 with a PS/2 mouse port.
What kind of graphics is onboard? Does it has the extension to 1 MB populated?
It seems to be this board:
https://arvutimuuseum.ee/th99/m/C-D/31460.htm
Reply 3 of 9, by chinny22
Nice! I've also still got our family's first PC, also a DX2/66 running dos/3x. My most used retro PC even though I've better suited 486's or other PC's
As for drivers, not much is needed on a dos/Win3x PC
Motherboard resources are all managed by dos and don't require any drivers
To give creative credit they still have drivers for all their soundcards available to download (SBBasic in this case) vogons drivers will just be the same version
The drivers also include useful software like mixer, CD player, etc but if your after the optimal stuff included with some products "TheMan" archived just about everything ever released for the ISA cards in an iso
http://www.vogonsdrivers.com/getfile.php?fileid=13
I cant find out what the onboard video is. Dos wont require a driver but you may want to get the Win3x one. This'll allow higher resolutions, maybe a diag tool or option to change 1 or 2 settings and enable any Windows acceleration is supported.
If you cant find the specific driver the standard SVGA driver available during Windows setup works 9 times out of 10 and will also give higher resolutions
Modem, Windows may include a US Robotics driver in the install? which does look "cooler" but Standard Modem will also work.
Back in the day you would use a modem to connect to a BBS and then internet. Windows doesn't include software for either of these.
IE5 is the last version supported version supported but this era screams Netscape if you ask me! Not like any of them play nice on the modern internet anyway.
Modern browsers exist but I'm not up to speed with them.
Windows had a few updates, This page has a list. The links are broken but gives you the patch numbers to google. You probably only need the File Manager Y2K update, Win32 extensions and if your going to setup networking then the TCP/IP update.
https://www.hpcfactor.com/support/patching/win31/
Windows did have a 32bit HDD access driver but don't think this was compatible with drive overlay,. It wasn't compatible with majority of hard drives even back then and performance didn't improve much.
Reply 4 of 9, by benjibarnicals
Hey all,
Thanks ever so much for the warm welcome! Putting this 486 machine together I almost forgot the joys of setting up your autoexec/config files 😀
chinny22 et al, thanks for your advice re the motherboard etc, this is indeed the one I have, it looks like im running the fastest DX chip I can (unless I could get away with a faster one?), Im thinking 16mb ram in here is probably enough. Actually, could you put an overdrive CPU in here?
Just on the Soundblaster, It looks like I have the CT2770A (2nd revision?). TheMans CD archive was perfect, he had the Panasonic interface CDrom drivers which works fine in DOS and Windows 3.11 and the full DOS/3.1 drivers and applications. This is working perfectly. Very nostalgic seeing these apps infact. Though my original machine has the AWE32, the apps if I recall are identical (well, enough to make me nostalgic).
So, motherboard wise, I've had a little look and it has a Western Digital graphic controller, it seems, 1mb of onboard memory with 70hz refresh upto 1024x768 (max), jumper controlled. So i've sorted out the jumpers to allow for 70Hz, though im running it at 800x600 using windows own SVGA driver (though only 256colours) at the moment. My original machine had a 1mb Paradise VGA card, though I can't find one of those here in the UK for love or money. However I could be tempted to get another ISA VGA adapter card if its worth it (though any thoughts on what would be worth a look, easy ish to come by?).
The US Robotics modem, I would love to get the original software/drivers, so its complete, though I'm not finding it easy to actually find a download that isn't being masked behind a "Use our easy driver installation software" wall. These seem to be pretty cheap on eBay so I might just find a seller who has the disks and buy it again (unless I can find a download somewhere).
I wouldn't mind putting a ethernet card in here too, I know 3com are quite compatible, though I wonder if you have any advice what would be a good one? I would mainly use it for transferring files over, probably not much point trying to get this on the internet (or if I would even want to).
chinny22 funny you mention BBS, I remember them well, back in the mid 90's trying them then getting yelled out from my dad for the phonebill! I actually collect old PC mags at the moment which most from the early 90's era has plenty of adverts for BBS' Its quite remarkable now, though where some of them were advertising 20gb+ of data was a heck of a lot back in those days!
BTW thanks for the patches/updates, I will take a look at these shortly.
Anyway, I've attached some BIOS photos, I can't upload more than 5 per post, I can upload more pics if needed.
Thanks all,
Ben
Reply 5 of 9, by chinny22
So the onboard video mystery is solved.
WD90c31A-ZS would be what you want to search under to dig up information or drivers. Looks like 1MB is as high as you can go so that's already upgraded.
http://www.vgamuseum.info/index.php/cpu/item/ … tal-wd90c31a-zs
Performance wont be great but I wouldn't rush off to upgrade just yet.
486's are kind of in the middle of era's plenty of power for earlier side scrollers and the like where even a slow card is fine but later games especially 3D shooters like doom start been held back by the CPU and a fast graphics card will only give a few extra FPS at best. hardly the difference between playable or not.
I'd just play Doom which is the upper limits of what a DX2/66 can play smooth and see how it feels.
You can also run its benchmark or Phils complete benchmark pack and see how for off the pace you really are.
https://www.philscomputerlab.com/phils-ultima … se-project.html
Bit for me compatibility is more important then speed, not sure how the chip fairs in this area. This list is for AGP/PCI cards but has the troublesome games you'll want to test against
https://gona.mactar.hu/DOS_TESTS/
CPU wise your limited to 5V CPU's, DX2/66 been the fastest 5v CPU
POD supports both 3.3 and 5V so may work, I assume this is what ODP586SX jumper settings means. Is it worth it? probably not. Difference on a "modern" 486 with either VLB or PCI isn't much let alone a system stuck on ISA.
Network card the #1 thing to look for is drivers. "NE2000 compatible" is similar to Sound blaster or even IBM compatible, that level of compatibility varies. So if you can find the specific drivers for a card your reducing the risk. 3Com drivers are easy to find and tend to utilise CPU a bit less, although I'm using some generic brand I got in the mid 90's and still had the driver disk, it works fine for file transfers... and playing lan games against other retro rigs 😉
Yeh I caught the tail end of BBS. Was given a 2400bps modem in mid '95 and only had 2 BBS servers in the area. I tried downloading Terminal Velocity of a 3rd I thought was in our local area. line dropped before it completed and phonebill next month showed Telstra (Aussie BT) had other ideas of what local meant. Dad was surprisingly ok and simply said "Wont be calling them again will we"
By Feb '96 though our DX2/66 had been upgraded to Win95 and gained a 33.6 modem and internet.
Reply 6 of 9, by philandrieu
Hello everybody,
I'm actually renewing a 486 and found this exact board for my project (the one you're quoting here) : DD & TT Enterprise DT-LB2AL.
Ref : https://theretroweb.com/motherboards/s/dd-and … terpri-dt-lb2al
Just made a bios dump and wanted to share it with you.
Hope it'll help someone in a near future.
Best regards.
Phil
The attachment DT-LB2AL.zip is no longer available
evasive wrote on 2021-05-11, 06:28:
Hi-res picture and bios dump wanted 😁
http://www.win3x.org/uh19/motherboard/show/1538
Reply 7 of 9, by RetroPCCupboard
Looks like a lovely machine. I have a slightly more modern Viglen PC. 400Mhz Pentium II in it and a Rage Pro graphics card....
It is in need of restoration, as you can see!
The attachment 20260807_182051.jpg is no longer available
But I think it is one of my favourite machines in terms of aesthetics
Reply 8 of 9, by Law212
Thats a great looking machine. I love 486 computers. I have two of them at the moment. I do not have my original family 486 which was a packard bell.....
Setting the, is fun. You just need to get a 5.25 inch floppy drive for that one!
Reply 9 of 9, by Intel486dx33
In America Peoples were so busy working they did not have time to experience
Everything that computers and software had to offer.
Thanks to retro computer enthusiasts they are helping to make
Sense of what was actually going on back in the 1970, 80, 90.
I would’ve say that you need to pick a priority
Period correct hardware or hardware with the best compatibility
For playing games and running software.
It’s only a 486 computer in the end it can’t play mp3 or videos
If you want the best dos game compatibility i say get a Pentium class
Computer like a Pentium 133 or 200mhz for dos, win 3.1, Win95
Pentium -3 for Win98, win-me, win2000
