First post, by Woody72
Hi guys, Bit of a daft question probably bit I'd like to snag up a couple of spare PSUs whilst they're still around. I've tried searching for 'AT power supply' with mixed results but is there a better term I should be searching for? I'm referring to the PSUs with the side by side motherboard connectors and a physical switch. TIA.
Modern PC: i7-9700KF, 16GB memory, RTX 3060. Proper PC: Pentium 200 MMX, 128MB EDO memory, GeForce2 MX(200).
Reply 1 of 2, by Errius
Lots of detail here
https://czman11.tripod.com/pwr_sup_formfact.pdf
AT PSU = Huge thing the size of a shoebox
Baby AT PSU = Smaller but still very large by modern standards, roughly cubic in shape
LPX PSU = Same size as modern ATX PSU but using the older AT connectors
Additionally you have to distinguish between 'desktop' PSUs with rocker button on the side and 'tower' PSUs with the switch on the end of a cable.
"AI Requires Proof That You Are Human"
Reply 2 of 2, by Woody72
Cheers Errius, I'll have a read of that 👍.
