First post, by Erwin_Br
Hey guys,
Is it possible to change the IRQ to 7 on a SB16 Vibra?
The reason I ask is that I'm having trouble doing so with the CTCU utility. The option is simply not there, it only displays 5 as an option.
I also tried to manually edit CTPNP.CFG but it gets overwritten back to 5 after a reboot.
There should be no other things blocking IRQ 7, I even disabled the LPT port on the mobo.
Any suggestions?
The attachment Screenshot 2021-05-16 at 17.21.23.png is no longer available
