First post, by RiP
I found a new Micropolis 1991WAV hard disk but none of my Adaptec/LSI SCSI cards can detect it 🙁
I have not had any problems identifying SCSI hard drives so far. Are there any settings I missed?
http://www.mfarris.com/hard_drives/micropolis … is_1991wav.html
Reply 1 of 4, by evasive
Many things can go wrong with SCSI.
Is this the only device on the controller? What controller exactly are you using? Separate terminator on the cable or not? Is it a known good cable? What SCSI ID is the drive set for? Is autodetect enabled on the controller? And so on.
Reply 2 of 4, by darry
Later Micropolis products had a less than stellar reputation for reliability, to put it mildly.
AFAICR, that 9GB model was something of a minor legend on that front .
Reply 3 of 4, by evasive
Oh I forgot, does it have any marking (sticker, sharpie) that says "DOA"?
Reply 4 of 4, by Grzyb
"Int.Type D/W"
It probably means Differential Wide.
Can't work with a Single Ended host adapter, more: damage is possible.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
