First post, by Jim5589
Hi I wondered if someone could point me in the right direction for this. I have a 486 Motherboard which I want to fit Cache sockets to rather than have the memory directly on the board. but I cannot find them anywhere online to buy. I can find 28 pin ones but all the 32 pin ones I can find are to wide. If anyone could link me to the right thing or suggest where to look in case its somewhere I haven't checked I would be grateful thanks. I am in the UK by the way so preferably a UK company but at this point anywhere will do!
Reply 1 of 8, by fgenesis
32pin narrow-dip? I'm not even sure this exists, can you post pictures?
As a quick workaround you may get some 16p ones (eg. https://www.aliexpress.com/item/1005001333427116.html) and use two in a row to form a 32pin socket. Not so pretty but should work.
Reply 2 of 8, by mkarcher
fgenesis wrote on 2021-05-18, 13:19:
I failed to find anyone selling those sockets, too. They definitely do exist (did exist?) on late 486 mainboards. 512kBit and 1MBit SRAMs (like the infamous "ISSI" 10ns chips) have a 32pin narrow case. They were used for 256K single-bank cache (cheaper than 256K dual-bank) and for 512K and 1M cache sizes.
Reply 4 of 8, by Jim5589
Thanks for the replies. At least I know I cant get them rather than I couldn't find them. I will order up one of the solutions suggested
Reply 5 of 8, by fgenesis
mkarcher wrote on 2021-05-18, 13:55:
The attachment DSC00805.JPG is no longer available
These? Got those from aliexpress about a year ago, so far not used.
Could you elaborate a bit? Is there are problem?
I planned to stuff them into a mainboard that supports them and isn't maxed out.
Or are you referring to some shady mainboards with fake cache chips?
Reply 6 of 8, by Jager
IS61C1024 datasheet has no information about 10ns version + markings 100% fake.
In my case 1 out of 5 was dead, other work fine in my HOT433 rev.4 with fastest timings & 33MHz bus.
Reply 7 of 8, by fgenesis
Ok, so not an original part but someone made them and marketed them under a fake ISSI name. löl, figures. As long as they work with my 133 MHz pentium i won't complain...
Reply 8 of 8, by mkarcher
fgenesis wrote on 2021-05-18, 20:39:
Exactly. Consensus is: They seem to have bad quality control (expect around 10% "dead on arrival") and I think no one tested whether the 10ns specification is real. On the other hand, the chips that are not dead work perfectly for many VOGONS users, and no one complained that they are "way too slow", so likely they are 12ns or better.
