First post, by Scythifuge
- Oldbie
Greetings,
I got my 4DPS all hooked up and it seems to be running stable. However, it doesn't detect optical drives during boot; only when the drivers are loaded. I am getting an environment variable and switch error when using the dir command, though it still displays the directory. When I use the dir command on the slaved DVD drive, there is a hiccup and is displays the directory list, though it is slower.
I have read that the 1.72f bios offers more stability and improvements and detects ATAPI drives during the boot process. However, the bios chip is one of those erasable by UV light chips. I have heard of bios services and what not. What is the easiest and best way for me to go from the 1.5 bios to the latest bios?
Thank you!
Scythifuge
