bug? "for" command
First post, by tauvan
I just started (newbie) DOSBox. Mounted an a: and a c:. From either
a or c tried to run install. Install is a bat file which calls "for".
Dosbox response:
"Illegal command: for."(return)
"Invalid drive specification."
I guess I'll have to install by hand. But wished to report if bug or find
out what I did wrong.
Thanks
Reply 1 of 6, by ASM
Hm FOR is a batch command for creating loops but I don't know whether it was already available in DOS... 😕
Reply 3 of 6, by tauvan
after hand copy (bypass install) the exe starts but ask to insert orginal
disk, hit return then dies.
Reply 4 of 6, by Zorbid
Mount the floppy as a: -t floppy in DOSBox (or mount a directory where the content of the floppy is copied , with the -t floppy as well)..
If it doesn't work, try to dump a disk image of the game, and imgmount that image as a:..
Reply 5 of 6, by tauvan
it turns out that it a copy protection feature. the volume name has
punctuation which can not be duplicated with the "label" command.
However, the "for" command is still in error.
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
well the punctation can be solved by making the name long enough
1234567890
->12345678.90
Water flows down the stream
