First post, by Hydrohs
I'm having some sound related issues with the Audigy 2 in Windows 98. I've got it installed fine and it's working, but CD audio from images mounted through Daemon Tools is constantly skipping. I tried another Audiy 2 card I had (exact same model) and it experienced the same issue, but using an SB Live that I have works fine so I'm assuming it's an issue specific to the Audigy 2. I'd prefer to use the Audigy 2 if I can since I have the 5.25" front panel bay for it. I'm not sure what the issue might be, though.
Reply 1 of 4, by schlomoe99
What is your system configuration?
-Motherboard
-CPU
-RAM
-Audigy 2 driver version
-etc;
These will all help us understand your problem better.
Reply 2 of 4, by Hydrohs
schlomoe99 wrote on 2021-05-24, 12:57:
What is your system configuration? […]
-Motherboard
-CPU
-RAM
-etc;
Sure:
Chaintech 6VTA2 motherboard
PIII 850MHz
256MB RAM
I installed the software from this CD: http://vogonsdrivers.com/getfile.php?fileid=5 … menustate=45,38
Reply 3 of 4, by schlomoe99
Try the solution in this thread to get the VXD drivers installed, replacing the WDM drivers may help:
Audigy 2 Win98 VXD drivers for non-ZS models
The thread references this CD to install VXD drivers:
http://www.vogonsdrivers.com/getfile.php?file … 397&menustate=0
Good luck!
EDIT: Disregard. 98SE will likely only support global digital audio extraction with WDM audio drivers installed. Some posts disagree with this assessment, so not a sure-thing.
Reply 4 of 4, by Hydrohs
schlomoe99 wrote on 2021-05-24, 14:53:
Try the solution in this thread to get the VXD drivers installed, replacing the WDM drivers may help: Audigy 2 Win98 VXD driver […]
Good luck!
That's what I thought as well. However, it's now all working.
I had fully switched over the Live! in the meantime since it at least worked correctly, and I installed the drivers for the Audigy 2 ZS following Phil's guide: https://www.philscomputerlab.com/sound-blaster-live.html
When I swapped in the Audigy 2 it was recognized and Windows installed the drivers, afterwards it's working perfectly. If anything ever goes awry then I'll give that other disc a shot, but at least on the surface it appears that the Audigy 2 ZS VxD drivers work for this case.
