First post, by Malik
Is there any way to convert the Teledisk or Kyroflux raw dumps to .img format to use in emulators? I tried searching online but couldn't find the exact process. Most websites are simply talking about preservation and writing back to floppy drives.
Thanks for any info.
Reply 1 of 5, by Jo22
You're apparently right and I wonder the same.
A quick Google search returns this:
"The Kryoflux company claims ownership of all images created with Kryoflux hardware."
https://news.ycombinator.com/item?id=24948485
Which apparently is about the image format itself.
Perhaps that's why no converter application has been made so far, not sure.
If nothing works, maybe a virtual floppy drive or a Gotek device with FlashFloppy, HxC can be used to get an IMG/IMA file.
Edit: I'm not sure, but maybe the KryoFlux software can create "Sector Images" somehow.
As opposed to STREAM or DRAFT images.. Of course, only owners of a KryoFlux+Softare have this privilege.
https://goughlui.com/2013/04/22/project-kryof … -of-the-images/
Reply 3 of 5, by konc
About Teledisk: yes you can, but you will obviously get a working image only if there are no "special" things in the image. In other words, only if you could get a working .img/.ima in the first place.
Teledisk (not the shareware version I believe but I'm not sure on that) has a TD2IMA.BAT file that does exactly this
Reply 5 of 5, by Malik
Thank you for all the replies. I'll use the above mentioned programs.
