First post, by jasa1063
I now have 3 Asus Socket 7 motherboards:
TXP4 with a Cyrix MII PR300 (@233MHz)
P5A Rev 1.04 with a K6-III+ 450 (@600MHz)
P5A-B Rev 1.05 with a K6-2 500 (@550MHz)
All three have been rock solid with excellent performance. I cannot say the same of some other boards Namely my MSI MS-5169 Rev 4.0, Shuttle Hot-597 and Amptron PM-8600B. All three of those motherboards have had issues of one sort or another. The MS5169 did not want to play nice with UDMA modes in Windows 9x. The Shuttle Hot-597 was very picky on SDRAM modules and the Amptron PM-8600B was just plain bad on all fronts. The P5A replaced my MS-5169 and the TXP4 replaced my PM-8600B.
I would interested in hearing about other's experiences with Asus Socket 7 motherboards.
Reply 1 of 2, by bloodem
The P5A Rev 1.04 + K6-III+ 400 (OC @ 575) has also been rock solid for me. In fact, all Asus boards that I own have been great.
Then again, most of my other Socket 7 boards (once certain quirks were debugged/sorted out) have been nice and stable:
- DFI K6XV3+/66
- DFI P5BV3+
- Azza PT-5VMD
- Lucky Tech P5MVP3
- Acorp 5TX29
- Zida 5DTX
EDIT: Regarding the P5A Rev 1.04, I just remembered having an issue when initially testing it: it would completely refuse to load Windows. It would also completely refuse to load Windows setup (either from a CD or from the HDD). After some debugging I discovered that the issue was caused by my modernish PS/2 optical mouse (which worked great with any other board before that). I then switched to another modernish PS/2 optical mouse and haven't had any problems since.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 2 of 2, by Repo Man11
I've had several over the years (TXp4 and P55T2P4), beginning with a P55T2P4 that I bought in 2001 to use with a K6-2+ as an inexpensive upgrade to the BiostarVX/Winchip 200 combo I had, and they've all been solid performers for me.
