First post, by Christy
Hello,
I wanted to run an old DBase application with DOSBox. When I fire up my application I get the error message:
Error DBF/1001 Open error: MyFILE.DBF (DOS error 2)
Under VMWare I had ot change the config.sys with the two following parameters:
FILES=80
BUFFERS=20
Can I enter these parameters somewhere in the DOSBox config file?
Thanks a lot for your help!
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
error 2 ... hmm file not found
are you sure you mounted everything corretly ?
Water flows down the stream
Reply 2 of 3, by Christy
I mounted the directory containg the working application under vmware. The MyFILE.DBF is also located in that directory.
Any idea?
Reply 3 of 3, by MiniMax
Rank Moderator
Moderator
Christy, how do you start DOSBox? How do you start your application? Please let us know exactly what you do and which commands you use.
_________________
