DirectX compatibility?
First post, by Zup
I was doing a list of compatibility for Windows retro machines, and I've got some doubts with DirectX.
This are my notes...
  • Until DirectX 9, higher versions keep compatibility with lower ones. So a PC with DirectX 8 should run every game that requires DirectX 5 (more about that later).
  • From Vista onwards, every OS seems to have their own DirectX (Vista being DirectX 10). The only exception is Windows 7, that can have a version of DirectX 12 installed.
  • But, because some games requires some DLLs from DirectX 9 that may be not installed on modern Windows (i.e.: d3dx9_39.dll and d3dx9_43.dll), it would be a good idea to install a DirectX 9 runtime on later OSs (I've got a runtime from June 2010 that has both libraries).
  • DirectX 3.0a is the latest version that runs on NT 4.0. There is a beta version of DirectX 5 that can be installed, but... why using a NT workstation for gaming?
  • DirectX 6.1a 7.0a is the latest version that can run on 80486 processors. But I can't imagine why anyone would want to run a DirectX 6 game on a 80486 (It's 7.0a. Tested on PCem using Windows 95 on a 486 board).
  • DirectX 8.0a is the latest version that can be installed on Windows 95. There are people that states that DirectX 9 can run on Windows 95, but every bit of information I've found says that it's not compatible.
  • DirectX 9.0c (July 2004) is the last version supported on Windows 98 (some later 9.0c versions can be installed on Windows 98SE, but I guess that sticking to that version is fine). It is strange that Microsoft used DirectX 9.0c as a kind of "rolling release" (well, I guess DirectX is a rolling release now)... there are at least 5 versions listed on wikipedia with the same number.
And two special components of DirectX that should be mentioned...
  • DirectX Media seems to be an additional installer to DirectX, and a succesor to ActiveMovie. It includes old video codecs and some DLLs that seems related to DirectX, but it seems that it was never integrated into it (or maybe the functions on that DLL were put on other DLLs). Does anyone knows what is the minimum DirectX required to install DirectX Media? If it was integrated inside DirectX... what was the first version that includes that?
  • DirectPlay was deprecated on DirectX 9 (and substituted by GWFL), and it seems that DirectX 9 and later installers do not include DirectPlay DLLs. Do DirectX 9 support DirectPlay or should DirectX 8 be installed prior to DirectX 9 to ensure that DirectPlay games works fine? I thought that there was a standalone installer for DirectPlay (like the DirectX Media one), but I can't find it... maybe my mind is playing tricks and there was no installer? but DirectX 9 still has some DLLs from DirectPlay (I was wrong, see below).
I'm selling some stuff!
Reply 1 of 28, by xcomcmdr
My bad about directX 9 on Win95, I haven't used it in a very long time.
Reply 2 of 28, by Zup
A few more things that I've found...
  • I haven't found any file from DirectX Media on any DirectX installer (i.e.: danim.dll or ir41_32.ax), so I guess that DirectX Media never was included with DirectX. Maybe it was included on Windows Media Player installers (because it was the successor to ActiveMovie and predecessor to DirectShow), or even on some Internet Explorer installer.
  • Or maybe it was only a tool to ensure that old codecs were installed and games could show movies without crashes.
  • Still I don't know when (at which DirectX version) did DirectX Media appeared. On DirectX Media installer are some kind of DirectX "mini distro" (very minimal, only to show things on screen), but I can't tell which version is.
  • DirectPlay seems to have appeared on DirectX 5. After that it was overhauled on DirectX 8... and deprecated in DirectX 9. DirectX 9 still have some DirectPlay DLLs (dpmodemx.dll, dpserial.dll and dpnet.dll) and seems to be compatible with DirectPlay... but dpnet.dll is not installed on that version.
  • After that, DirectPlay was included as a "system feature" on Windows Vista and later versions, so can be installed/uninstalled without touching DirectX... but that "system features" thing is like a "hidden things" menu.
Reply 3 of 28, by The Serpent Rider
DirectX 6.1a is the latest version that can run on 80486 processors
DirectX 7.0a.
Reply 4 of 28, by Jo22
Hi! Vista got DX 10.1 with SP1 and finally, DX 11 a few years later..
From what I remember from my faulty memory, though, not all features were
accelerated or not as feature complete as in Win 7
due to the older driver model in Vista.
https://www.tomshardware.com/picturestory/518 … x-11-vista.html
Windows 7 also got a pseudo-DX 11.1 at some point.
It was part of an update of some sort.
https://walbourn.github.io/directx-11-1-and-w … ndows-7-update/
Edit : Quote added. Also, yes, Windows 7 got DX 12 shortly before it became EOL.
However, it never got an SP2. 🙁
Except if we count that strange "Convenience Rollup" as SP2.
Reply 5 of 28, by dr.zeissler
I mostly use DX5 or DX6.1a on Win95 machines. Games that require DX7+ will not work good on that old K6/P2 because I mostly use low-end onboard GPU combined with Voodoo1 or PCX1/2. With DX6.1 you mostly have all your 3dfx-games working already.
Reply 6 of 28, by Jo22
dr.zeissler wrote on 2021-05-28, 14:06:
That's interesting. Do you know, by any chance, if it's true that the DirectXin Windows 98SE (v6.1?) uses MMX if available?
I though that was the case, but I'm a bit unsure about it.
From what I also remember, the Windows 98 kernal or some system files had MMX versions.
Not sure though, if that's really the case and/or if they were only copied if MMX was detected during Windows installation..
Ah, well. 😅 My memory is a bit sketchy here. I just remember two things vividly from the eaely 98SE days - the MMX craze and MS Motocross Madness! 😁
Edit : https://jdelezenne.github.io/Codex/History/DirectX.html
Reply 7 of 28, by BitWrangler
Listening in, I feel like I spend more time fighting DirectX than I do playing games.
Perhaps I'm remembering wrong, but I thought I had DX7 games playing on Voodoo3 back in the day... without DX7 features of course.
Reply 9 of 28, by dr.zeissler
Yes I read about DX6 that uses MMX and some 3Dnow Optimizations. For 3dfx MMX it is not really important. I remember Games that worked smooth even on P133/166 with 3dfx (voodoo1) and not much better on 200mmx with 3dfx (voodoo1). That may be different in higher CPU-Classes. I mostly stick to the features and drivers of the GPU. If the GPU is DX5 then I install DX5. If the gpu has DX6 drivers I use DX6.
When installing higer DirectX Versions I don't get much benefits, mostly I run into different problems, so I stick to lower DX-Versions. Running DX3 on Win95 was a not a good idea, because there are only a view games that work with dx3.
My actual testing machines are setup with:
Scenic Micro-Desktop K63/450 RageIIc PCX1 Win95/DX5
Scenic Micro-Desktop P3/500 RageProLT PCX2 or Voodoo1 Win95/DX6.1
Scenic Micro-Desktop P3/600 815e / Voodoo1 Win98se DX7
Scenic Micro-Desktop P3/1400 PCI 9250 or R7000 Win98se DX8
I have tested lot's of scene-stuff against different dx-versions and so a have a bunch of cool demos for each machine. It's good to have different setups to play with. There is always a surprise what can be done with such cool hardware.
Reply 10 of 28, by thp
A bit late to this thread, but the Falconfly page has quite a few DX versions for download, including a handy OS compatibility matrix (this also includes date-based releases of DX 9.0c):
http://falconfly.vogonswiki.com/directx.html
Reply 11 of 28, by AppleSauce
Was DirectX version 1.0 actually used for anything?
So far I can only find Directx 2.0 games as the earliest so I was just curious.
Reply 12 of 28, by leileilol
Cyberspeed and Locus are the earliest I can immediately think of.
Reply 13 of 28, by Jo22
And as far as I remember DirectX 1 was DDraw only still (no D3D yet), so 3D games had to use their own 3D engines.
I'm just saying, because of 3D glasses. These need an API with a concept of depth, such as Direct3D.
Reply 14 of 28, by BEEN_Nath_58
AppleSauce wrote on 2022-10-22, 15:30:
Didn't Zork Nemesis use DX1?
Reply 15 of 28, by leonardo
Edit: Sorry about polluting the thread - I usually dislike reading off-topic posts that derail the thread, just like the one I made here.
Ill conceived rant about how evil MS is which has only peripheral attachment to topic
DirectX was just Microsoft's way of trying to tie PC platform game development exclusively to Windows. It kind of sort of worked, even though up and until about DirectX version 8/9, most devs would just prefer OpenGL instead of Direct3D/DirectDraw.
John Carmack can quite famously be quoted saying that early versions of D3D were an absolute time-waster and not worth a developer's attention. Well.. that was then and OpenGL kind of became its own bloated mess as the years went by.
DirectX went through 8 iterations during the lifespan of Windows 95 (think on that for a minute- one OS got eight releases!). Now you get maybe one for each version of Windows (gotta upgrade to the next version to get the latest DX) and of course with the game devs doing their work mostly targeting DirectX, multiplatform development became significantly more costly and unlikely. Your video card's abilities are now also tied to DirectX-features.
I started to notice this around DX8 and 9-era as well. Your graphics card may have been king in DX8-land, but give it a DX9 game and suddenly it looks like crap and runs like molasses. That's probably why I lost interest in PCs as a gaming platform around the mid 00's. Now there is no hope of getting cool looking games optimized for anything other than team blue/red's latest DirectX-compliant hardware.
Sorry about the rant, maybe there's something useful in there for someone...
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 18 of 28, by BEEN_Nath_58
leonardo wrote on 2022-10-22, 17:57:
DirectX was just Microsoft's way of trying to tie PC platform game development exclusively to Windows. It kind of sort of worked […]
That applies to DirectX graphics. Games otherwise still needed to use the DirectSound/DirectInput/DirectPlay APIs too.
Reply 19 of 28, by akula65
Jeff Vavasour has indicated that Williams Arcade Classics used DirectX 1. See the Midway Arcade Treasures section on this page (WAC is discussed earlier on the page):
http://www.vavasour.ca/jeff/games.html#mat1pc
