First post, by Limpem
Hey Everyone,
I have a question to which I couldn't find the answer (unless my searching skills fail me).
I want to know what the fastest cpu is to pair with a voodoo 1 and maintain full dos compatibility.
The known limits I could find:
-Above 400 Mhz some games start to have glitches, but to what I could find, this only concerns some directx titles.
-Voodoo 1 cards don't like cpu's with a 133 Mhz FSB
-When the cpu is too fast, old dos glide games can have trouble detecting the gpu <-- I couldn't find the exact limits anywhere
So in order to find those limits I started testing with a BX440 system with the cpu's (also have a slot-t adapter) I had at home.
Games I used for testing:
  • Battle Arena Toshinden
  • Carmageddon
  • Descent II
  • Dreams To Reality
  • Extreme Assault
  • Fatal Racing
  • Grand Theft Auto
  • Lands Of Lore II
  • Nascar Racing 2
  • Prost Grand Prix
  • Screamer 2
  • Shadow Warrior
  • Starfighter 3000
  • Tomb Raider
Here are the results of my tests with the cpu's I had at hand:
file.php?id=111184&mode=view
I think the 1133s Tualatin is the fastest cpu that still works when running at a 100 Mhz FSB.
Starfighter 3000 sometimes had problems detecting the voodoo1 with that cpu installed, but if that happened, a simple reboot would make the game detect the voodoo1 almost every time.
I think the issue is more related to the actual clockspeed rather than performance since the 1133s performs at 850Mhz very similar to a celeron tualatin at 1000 Mhz due to the larger L2 cache.
But because of the problems starting at this speed I think going one step up (1266s or 900 mhz coppermine) will immediately impact compatibility
Since I don't have any other cpu's to test, I am curious if someone was able to get the voodoo 1 detected by dos glide games with even faster cpu's (and if so, what chipset and cpu were you using at which speeds).
I am specifically not looking for well meant advise as: "why would you want to pair a cpu that fast with a voodoo1" or "anything above 400 Mhz is overkill for a voodoo 1"
Just curious to find out what the upper limit is in terms of detectability
    28.75 KiB
430HX/P1 233MMX/64MB/S3VirgeDX,Voodoo1SLI(King Shaman)/AWE32
440BX/CelTualatin1400/512MB/Banshee, PowerVR PCX2/AWE64Gold
645DX/P4Northwood 3,5Ghz(Oc)/512MB/Voodoo5500/Vortex2
875P/P4EE 3,4Ghz/1GB/GeforceFX5950/Audigy2ZS
Z97/i3-4370/16GB/GeforceGTX960/X-Fi
Reply 1 of 23, by pixel_workbench
I ran a Voodoo on a s478 system with a 3.06ghz Pentium4. Probably something unique to the Sis chipset, because I wasn't able to get the same success on an Intel 845 board with a slower P4.
https://pixelworkbench.com/2019/12/15/ ... 1-review/
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 2 of 23, by Limpem
Wow, that's quite impressive!
Dit you try other DOS games except Tomb Raider?
According to my own tests Tomb Raider seems to be the most forgiving when paired with faster cpu's (while Starfigter 3000 seems the most limited).
Reply 3 of 23, by Limpem
I checked my hardware, I don't have a system with a Sis 651 chipset, but I do have an Asus P4S533 with a Sis 645DX chipset.
Unfortunately I have no time to test anything this week, but I can't wait to give it a spin next week and see if I can get the same results! 😁
Reply 5 of 23, by Limpem
Well I finally was able to do some testing on the Asus board with the SIS chipset.
It seems that going for a SIS chipset actually makes a difference!
I paired the board with a Pentium 4 HT running at 3.06 Ghz.
When I tried to start GLquake with the voodoo 1 I got a colorful screen and the system crashed, which is a known issue when running this card at a 133 bus-speed.
I then went into the bios trying to change the bus-speed, but I could only increase it, not decrease it.
When I started playing with the memory multiplier (not doing 1:1) stability increased, I was able to do a benchmark in glquake, but I did see some graphical glitches.
As soon as I tried any dos-game It would immediately hang unfortunately.
Then I downloaded the manual for the motherboard.
I discovered I can change the bus from 133 to 100 with jumpers and switches on the motherboard, thereby eliminating the need for those speeds in the bios.
After changing the bus-speed to 100 (and hereby lowering my cpu speed from 3.06 Ghz to 2.3 Ghz) I tried again.
Glitches in GLquake were gone immediately.
Tomb raider (static linked version) worked.
Shadow warrior worked.
Fatal Racing crashed at startup.
Trying Anthony’s method by running shadow-warrior before fatal racing didn’t seem to work in this case.
At this point I ran out of time for testing, but wanted to share my findings so far.
I want to continue testing over the weekend.
Reply 6 of 23, by Limpem
Well it took me some time to do additional testing, but I can confirm that a voodoo 1 works great with a 3,06 Pentium 4 on a SiS chipset (running at 133FSB!).
Fatal racing not running was due to a missing sound-card (even though I disabled sound in the setup). After installing an ESS-SOLO1 Fatal racing worked great!
All the games from my list seemed to detect the voodoo 1 and work.
I did have to restart the system occasionally after running multiple games after each-other, but after a reboot it would always work.
Compatibility from pure-dos was a lot better compared to running the games from Windows 98 (did crash or glitch occasionally).
Another interesting find was that Incoming did not have any graphical glitches on this system!
On my slot 1 system, the glitches already start at 450 mhz, but somehow on the SiS chipset it just works…
The bugs I had with quake1 disappeared when I put some active cooling on the voodoo1 by placing a large fan in front of it.
Since SiS made chipsets up to the core2 era, this does make me curious if it would be possible for even faster systems to work with a voodoo 1 😁
Does anyone out here have such a board and is willing to test this?
Reply 8 of 23, by Limpem
I have 2 voodoo 1 cards:
-Diamond Monster 3D Rev E
-Anthony's King Shaman (voodoo 1 in SLI)
I still wouldn't recommend this motherboard for a voodoo 1 setup.
Every game I try works, but I do experience instability at certain points.
For example every time I startup or shutdown Expandable there is a high chance the system will hang, but once it runs, it runs absolutely flawless.
Reply 10 of 23, by Aebtdom
underage wrote on 2021-06-18, 00:23:
how well does the voodoo1 scale with a faster cpu?
I think you will have great performance improvements up until 300mhz. After that it is just minimal until about 450mhz.
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 11 of 23, by Limpem
I don't have much time this week, but I will do some benchmarks.
However I do agree with Aebtdom that a standard voodoo1 doesn't scale well above the 300-500 Mhz range.
The King shaman does however have more headroom due to the extra TMU per voodoo 1 and having 2 voodoo 1's in SLI.
This post is more for finding the fastest system on which you can still get a voodoo 1 to run without issues rather than creating a sane build for a voodoo 1 (I don't think many people here own a King Shaman or Quantum3D SB100).
Reply 12 of 23, by Aebtdom
True, at least i know for sure that the fastest amd processor will be the athlon k7 1400B the thunderbird model 4 aka A1400AMS3B.
After that the fsb goes to 133mhz.
Builds:
Reply 13 of 23, by BitWrangler
In theory, you could mobile mod a TbredB which gives it unlocked mobile multiplier (NF2 problems with that) run it at 100 and use up to 24x. But the 2400 and 2600 desktop have 15 and 16x out of the box, so would run 1500 and 1600mhz on 100/200. The barton 2600 and 2800 266 models also have 15x and 16x multis. (You can mobile mod a Tbred A or palomino also, but typically won't get more than about 1800 out of either.)
Beware if you want an ISA slot and a 1400B though, you might not find a motherboard that supports both ISA and a multi over 12.5... but mods can be done, it's an extra bit that might not have a jumper, but can be done with socket mods or wire tricks. However, mobile multi control might still work.
Reply 14 of 23, by bloodem
Interesting findings, but man... I have a hard time understanding the usefulness of running a P4 with a... Voodoo 1, when even Pentium MMX CPUs are bottlenecked by this card 😁
Even if you want to build the ultimate all-rounder, a Voodoo 2 would be much more versatile, with better image quality and also 98% compatible. 😀
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 15 of 23, by mothergoose729
bloodem wrote on 2021-06-21, 16:59:
I don't know if all platforms have this issue, but I have found a lot of Voodoo 2 patches for DOS games are speed limited. For example, I can't run Descent II at anything higher than 400mhz on my VIA C3, which is roughly equivalent to a pentium II at 200mhz. The software renderer doesn't have the issue.
Maybe Voodoo 1 patches are less sensitive? Or maybe it is just my setup.
Reply 16 of 23, by Limpem
Well I was finally able to do some benchmarks.
I used the following CPU’s:
-Intel Pentium 4 HT Northwood 3.06 Ghz (512KB cache) on SIS 645DX
-Intel Celeron Tualatin 1400 Mhz (256KB cache) on Intel 440BX
-Intel Pentium III Tualatin 1133 Mhz (512KB cache) on Intel 440BX running at 850 Mhz (100 Mhz FSB)
-Intel Pentium II Deschutes 400 Mhz (512KB cache) on Intel 440BX
For The GPU’s I used:
-Voodoo 1: Diamond Monster 3D Rev e
-Voodoo 2: Diamond Monster 3D II 12MB Rev ?
-King Shaman
The King Shaman is a very special card, due to it being a voodoo1 in SLI.
So I benchmarked it in three different ways:
-SET FX_GLIDE_SWAPINTERVAL=0 this option gives the highest FPS by removing v-sync, however due to the SLI setup this creates some kind of interlacing effect in fast moving scenes, I don’t use this option for actual gaming. In the benchmarks this will be shown as KS_S0.
-SET FX_GLIDE_SWAPINTERVAL=1 now the interlacing is gone, but as the benchmarks show, performance also takes a hit. In the benchmarks this will be shown as KS_S1.
-SET SST_SLIDETECT=0 This removes the SLI turning the King Shaman in a single voodoo 1 with 2 TMU’s and 4 MB per TMU (so a voodoo on steroids). In the benchmarks this will be shown as KS_SLI_Off.
Please note that even though the benchmarks of Expendable and Drakan ran on the 1400 and 850 Mhz CPU’s, they had significant graphical glitches.
Those glitches were absent when paired with both the 400 and 3066 Mhz CPU’s.
The Drivers I used:
-For Voodoo 1 and King Shaman, I used Ciacarhaman’s drivers
-For Voodoo 2 I used FastVoodoo2 4.6 drivers
The benchmarks I did were:
-Drakan Retail
-Expendable Demo
-MDK2 Retail
-GLQuake Retail demo1
-Quake II Retail demo1.dm2
-Quake III Demo demo001
-Quake III Demo demo002
-Quake III Retail four
-Unreal Retail Timedemo
-Unreal Tournament Cityintro
For cards that supported 800x600 I also did benchmarks at that resolution.
This is the first time I did some benchmarking, so please forgive any mistakes I made.
For example I made a mistake on the Drakan benchmarks at 1400 Mhz with the voodoo 2 (accidentally picked the Geforce 440 that was in the system) so I had those removed.
Due to the amount of time it took to create those benchmarks I didn’t want to redo that benchmark, and thought the remaining benchmarks would give a nice overview anyway.
Some interesting results I found:
-The King Shaman with SLI disabled performs similar in DirectX games as a normal voodoo 1. It seems the Quantum3D DirectX drivers are not optimized to take advantage of the extra memory and TMU. Glide and OpenCL do show significant gains.
-The Voodoo 1 has a slight benefit of a 3066 Mhz over a 400 Mhz cpu in very demanding games like Quake 3, however even with the faster cpu cannot produce playable framerates
-The King Shaman does benefit from the faster cpu’s, but produces very similar results between 850, 1400 and 3066 Mhz. Due to compatibility with DirectX games, the 3066 system is however still an interesting system.
So here are the benchmarks:
file.php?mode=view&id=113975
file.php?mode=view&id=113976
file.php?mode=view&id=113977
file.php?mode=view&id=113958
file.php?mode=view&id=113959
    169.4 KiB
    182.38 KiB
    151.41 KiB
    141.5 KiB
    139.68 KiB
Reply 17 of 23, by Limpem
I upgraded to a Tualatin 1266 (512KB cache) which runs at 950 Mhz due to the 100 Mhz FSB.
Interestingly, when I run Phil's dos benchmark suite, it's almost always faster than the 1Ghz tualatin celeron due to the double amount of cache.
Therefore it seems issues with a voodoo 1 on a 440BX chipset are solely related to the clockspeed of the cpu and not with the performance the cpu actually can deliver.
Any statically linked game I try runs fine on the 950 Mhz cpu, while the 1Ghz celeron gives a lot of issues.
Only issue I found with the 950 Mhz so far is that is sometimes doesn't like to run 2 different static-linked games after eachother without a reboot in between.
Reply 18 of 23, by Gmlb256
Very impressive that you managed to get the Voodoo Graphics card working on such fast computer. 👍
One little pet peeve of mine though: These Voodoo cards you benchmarked aren't GPU, they're just really 3D acceleration cards without 2D capabilities and T&L.
Reply 19 of 23, by il_carletto
Sorry to revive an old topic, but I just managed to put together a retro-pc based on an duron 1200 on a ECS Elitegroup k7zva mobo and tried to install the skywell magic 3d plus voodoo card with 8mb ram I saved from my first pc in the ninetees.
Hardware is automatically acknoledged by windows and drivers are updated to the latest available ufficial version, everything seems fine but when I start up a game using it i get a blocky magenta screen and system hangs.
Tested games were tomb raider, screamer 2 and wipeout 2097, always the same output.
Fsb set for the duron 1200 is 100mhz and I know that over 450 mhz processor this card has issues, but as here people has succeded in running it at higher speeds I wonder if there some settings I can tweak to try to make it work.
I'm pretty sure that 3dfx card is working because before the duron I had a faulty slot A pentium III 500mhz and I could "play" expandable demo experiencing the expected fuzzy colors. In that case 3dfx was coupled with an nvidia mx 2 400 32mb and now it's coupled with a sapphire radeon 9000 128mb, don't know if this could have an impact.
