First post, by C0deHunter
Hello all,
I have an ASUS P5A Super7 Motherboard, and recently acquired an odd Pentium 75MHz CPU (A5013718CB - A80502-75 SX969). I am attempting to set the correct jumpers for the Front side, BUS , and Voltage, therefore I need your assistance:
- According to CPU-WORLD.COM, the Intel 75MHz seem to support 3.135V (MIN) / 3.3 V / 3.6 V (MAX) voltage
- It also seems to have a 1.5X Clock Multiplier
https://www.cpu-world.com/sspec/SX/SX969.html
https://www.cpu-world.com/CPUs/Pentium/Intel- … 0A80502-75.html
Other option (if I can not set the exact settings for 75MHZ frequency / 50MHz BUS), would be to maybe down-clock it to a 60 / 66MHz speeds?
Many thanks in advance!
    224.86 KiB
    323.61 KiB
    331.98 KiB
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 1 of 6, by melbar
C0deHunter wrote on 2021-05-29, 11:20:
60 / 66MHz speeds means overclocking , not downclocking.
This super socket 7 board is quite new compared the "old" pentium 75.
Yes, socket 7 boards are backward compatible to run a socket 5 also.
In this case, you can clock to a P90 (1,5 multi , 60 FSB) so it's overclocked.
See here the link to toms hardware:
They say: "P75 most of them run at least flawlessly at 90 @ 1.5 x 60 MHz, many of them at 100 @ 1.5 x 66 MHz."
Overclocking The Intel Pentium
But i would take care with the heat and would use a better cooler...
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 2 of 6, by C0deHunter
I see, thanks for the comments. So apparently there is no way that I can get to its manufactured 50MHz BUS speeds, it seems. 🙁
So for the jumper settings, I would set them like these then? (please see attached images)
    326.41 KiB
    337.72 KiB
    226.31 KiB
Reply 3 of 6, by melbar
Yes , this is the correct setting at pentium P54C 90Mhz.
You can set the vcore to 3.3 , 3.4 or 3.5 volt.
I would start with 3.3V and then have a look if everything is stable. Also take care to the cooling.
EDIT:
Anyway, you can try different speed levels with L1 and /or L2 cache disable setting.
Reply 4 of 6, by BitWrangler
melbar wrote on 2021-05-29, 11:36:
See here the link to toms hardware: They say: "P75 most of them run at least flawlessly at 90 @ 1.5 x 60 MHz, many of them […]
Every C2 stepping I've had would at least do 120, E0 are solid at 133, hot at 150 and you can find some that do 166, provided you're using a K6-2 sized heatsink and not one of those little pathetic 1cm high ones that P75s might have been blessed cursed with "stock"
Reply 5 of 6, by C0deHunter
Thank you so much for informative responses! OK, I managed to change the jumpers and everything seems to be working great, *except* that I get an error during BIOS boot, stating that there is voltage issue:
Per your suggestions, I am using the middle-ground 3.3 V VID, and the CPU came with a very large passive heath-sink, so I know it stays cool enough.
Please see the attached image.
Reply 6 of 6, by C0deHunter
UPDATE:
I loaded up the BIOS default settings, and the error message is gone, as it turned OFF all the settings for the ** VOLTAGE Monitor ** entry!!!
