First post, by jasa1063
I just picked up this motherboard and I am trying to find the motherboard audios drivers for Windows 9x, 2K, & XP. Any help would be appreciated.
Reply 1 of 8, by Repo Man11
This one should work: http://vogonsdrivers.com/getfile.php?fileid=1319&menustate=0
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 8, by soggi
Nice find! Because this isn't a Premium board from ABIT, it's a bit harder to find information about it. The "manual" states it has "Intel 82815E (MCH) + 82801BA (ICH2)", so an Intel AC'97 driver from that time should work.
Unfortunately it doesn't mention which AC'97 codec is soldered to the board...could you pls post the printing from little IC between game port / audio connectors, AUX1 and PCI1? Maybe there's another driver from the AC'97's manufacturer.
Repo Man11 wrote on 2021-05-30, 21:42:
If it's an AC'97 codec from Avance Logic (ALS, now Realtek), it should work. But then, why not taking the latest version A4.06 (could be found here: https://soggi.org/drivers/realtek.htm)?
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 3 of 8, by jasa1063
soggi wrote on 2021-05-30, 21:47:
Nice find! Because this isn't a Premium board from ABIT, it's a bit harder to find information about it. The "manual" states it […]
If it's an AC'97 codec from ALS (now Realtek), it should work. But then, why not taking the latest version A4.06 (could be found here: https://soggi.org/drivers/realtek.htm)?
kind regards
soggi
The lettering on the chip says:
ALC200
1448101-1340
Reply 4 of 8, by soggi
The ALC200 is an Avance Logic / Realtek AC'97 Audio Codec, so you'll be fine with the latest Realtek AC'97 drivers from my page! 😀
BTW please note, that you'll need an .7z compatible (un)packer like 7-Zip to extract the files.
kind regards
soggi
Reply 5 of 8, by jasa1063
soggi wrote on 2021-05-30, 23:28:
kind regards
soggi
The WDM drivers would not load, but I manually installed the Windows 95 drivers and those are working just fine. Thanks for your help!
Reply 6 of 8, by soggi
No problem, you're welcome!
BTW if you need the latest BIOS 8D for your ABIT SL30T (supports HDDs up to 137 GB and above, fixes some STR [Supend To RAM] issues), it's available on my ABIT motherboard BIOS page -> https://soggi.org/motherboards/abit.htm.
kind regards
soggi
Reply 7 of 8, by jasa1063
soggi wrote on 2021-05-31, 00:41:
No problem, you're welcome! […]
kind regards
soggi
Thanks, I just flashed the BIOS. I am now totally set!
Reply 8 of 8, by soggi
OK, if you have any further questions...just post! 😀
kind regards
soggi
