First post, by scrufy12parsecs
Greetings,
I'm running DOSBox 0.74-3, which I installed from package on the latest version of Mint GNU/Linux. I'm trying to install MS-DOS in DOSBox, which I'm close to completing. Where I'm getting stuck is being able to swap disks in the installation. Ctrl-F4 opens another TTY, since I'm on GNU/Linux instead of swapping disks. Is there another key combination that I can use or define? Does my autoexec.bat look correct? When I start DOSBox from the shell, I can see that it's loaded each installation disk and don't see anything that stands out as an error. Thanks for taking the time to offer some advise.
My autoexec.bat
imgmount a "/home/scm/OS/MS-DOS/Disk1.img" -t floppyimgmount c "/home/scm/OS/DOSBox/MS-DOS.img"boot "/home/scm/OS/MS-DOS/Disk1.img" "/home/scm/OS/MS-DOS/Disk2.img" "/home/scm/OS/MS-DOS/Disk3.img"
