First post, by cyberluke
Hi, I was experimenting with Teensy USB to DIN adapter, which has extra 5V USB power from wall adapter. It was working great. But after like 5 restarts, now the motherboard does not recognize any keyboard.
Connecting original AT keyboard results in continuous short burst of PC speaker noise. Like when someone holding a key.
Something wrong with onboard keyboard controller? Some over-voltage problem on DIN port? Is there some solution, please?
    1.29 MiB
    1.39 MiB
Reply 1 of 17, by chrismeyer6
Hopefully you didn't overload the keyboard controller on the motherboard and fry it. I would check the keyboard socket for maybe a bad solder connection and check the traces from the keyboard port to the keyboard controller chip for burnt traces or components.
Reply 2 of 17, by cyberluke
Ok, I got response from the maker of this adapter: "To protect the motherboard, a logic level converter (the smallest board) is installed on the adapter board."
"Furthermore, each motherboard has a fuse on the +5 volt line, I recommend checking this fuse.
Your motherboard is kept safe by these two safeguards.
Perhaps due to the high consumption of the keyboard, the fuse needs to be replaced."
So hopefully just fuse problem. I haven't spot any visible issues on the motherboard. I don't think it will be a bad solder connection. This week the machine was running daily.
Reply 3 of 17, by Nexxen
Can you post pictures of the motherboard?
Check on the keyboard V line if it goes to a filter (inductor) and check if it reads 0.06 ohm or higher, if higher it could prevent the correct voltage.
Just a thought.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 4 of 17, by Horun
As Nexxen said, a picture of the motherboard (or the make and model would be helpful). If no keyboard is connected does the motherboard boot but halt with KB error like it should or does it do something else ?
Reply 5 of 17, by cyberluke
Horun wrote on 2021-06-02, 23:19:
Yes, if keyboard not connected, it goes through POST and report KB error.
The board is ASUS 486-PVI-486SP3.
    1.74 MiB
Reply 6 of 17, by Nexxen
NOthing looks blown.
Could you check C1,2,4,17 and 18 if one has a higher resistance than 0.6?
You probably should take out the motherbaord at some point to check continuity between motherboard and keyb port.
Reply 8 of 17, by Nexxen
Maybe check if this applies to your motherboard, maybe you can avoid pulling out the mobo.
https://diagramweb.net/img/ps2-keyboard-to-5- … -diagram-12.gif
Reply 9 of 17, by cyberluke
Nexxen wrote on 2021-06-03, 00:58:
Funny that it's in Czech language...which is where I am right now. Anyway I have experience with software and Teensy. But this part, I bought on E-Bay. It worked for me with some cheap Genius USB keyboard. And the guy have working video on Youtube plus he is doing PC XT converters like this for a long time. This AT is just something new right now. So based on that, I would trust him, he knows how to connect the pins and shielding. I may raise a question, though.
Reply 10 of 17, by cyberluke
But I should not connect the Teensy to USB 5V. He clarified it is not needed. Which I did not know and the RGB keyboard won't even run without it. So I guess if there is some voltage from PC DIN (I guess 3.3V). Then there is some logic converter 3.3V to 5V. Then there is Teensy USB with additional 5V power line (probably extra), then there might be some problem like current going in from both sides and it might bring 5V to PC DIN under some special condition (like USB device, in this case the keyboard, gets disconnected). Maybe something like reverse polarity and it might blow up the fuse or something else on the board.
Reply 11 of 17, by megatron-uk
Check continuity on the 125v rated green fuse at the top left; it protects the keyboard/keyboard from over-voltage and shorts.
I had similar issues on my identical PVI SP3 ("no keyboard detected", "keyboard failure" - a quick flash of lights on the Kb itself, and then nothing) and it turned out the fuse had blown.
https://www.target-earth.net
Reply 12 of 17, by cyberluke
megatron-uk wrote on 2021-06-03, 07:18:
Okay, my keyboard does not even light up. I will need to measure it today.
Reply 13 of 17, by megatron-uk
Keyboard error and faulty fuse:
65.26 KiB
74.84 KiB
Removal and replacement of the fuse:
52.46 KiB
53.58 KiB
Reply 14 of 17, by cyberluke
megatron-uk wrote on 2021-06-03, 09:08:
Yes, that might look like it. Either the fuse or Amikey controller. But how to measure anything on the fuse? Fuse is only for current, you cannot measure any voltage or resistance on fuse, right?
Reply 16 of 17, by megatron-uk
Yes, just check the continuity of the fuse - put your multimeter into continuity mode and (with the computer off!) put one probe to one side of the fuse and the other probe to the other end. It will vary on your model, but on my (ancient) Fluke 75:
213.35 KiB
My guess is that there is none, your multimeter will not beep (most models will beep when they show continuity - or at least less than a trivial amount of resistance) or will show open-circuit or similar - ergo it will prove it has blown.
If it doesn't have continuity testing mode, just select resistance and measure it - in that mode it will show infinite resistance if it is blown.
Reply 17 of 17, by cyberluke
megatron-uk wrote on 2021-06-03, 10:03:
Yes, just check the continuity of the fuse - put your multimeter into continuity mode and (with the computer off!) put one probe […]
Yeah, I have only this DSO Nano v3. I updated the firmware, so it has some apps to measure voltage and resistance: https://www.seeedstudio.com/DSO-Nano-v3.html ...but normally it is oscilloscope
