First post, by jasa1063
I am looking for the firmware update for this drive. The latest I have seen online is 1.07. It currently has 1.05. The only link I found is no longer active, even using archive.org.
http://perso.club-internet.fr/farzeno/firmware/583_107.zip
Any help would be appreciated.
Reply 1 of 8, by AmiSapphire
Apparently this link should work: http://www.rpc1.org/farzeno/club-internet/fir … are/583_107.zip 😏
RPC1 site didn't update the paths when they mirrored the original site. I did locally download the file to test it, though.
Site update: cwcyrix.duckdns.org -> cwcyrix.nsupdate.info due to the former no longer working.
Reply 2 of 8, by jasa1063
AmiSapphire wrote on 2021-06-05, 05:06:
Thanks!
Reply 3 of 8, by darry
Ouch, that means that the day that site goes down (hopefully never, but life is life), the archive.org copy won't have those files .
Reply 4 of 8, by AmiSapphire
darry wrote on 2021-06-05, 13:51:
Seems the entire /farzeno/club-internet/ section is present: http://www.rpc1.org/farzeno/ This'll be less work on my part. Then again, rpc1.org itself is defunct and a set of archives only remain on that server. Should do a local mirror of it myself. (I already missed out on a bunch of historical Plextor files three years ago, however...)
Reply 5 of 8, by Horun
jasa1063 wrote on 2021-06-05, 13:38:
Thanks!
Can you please post the firmware update if you still have it ? Seems it cannot be found now.....
Thanks and Never mind. It was a browser issue 😀
Reply 6 of 8, by jasa1063
Here is the file just in case it is still needed anyway.
    583_107.zip
    87.1 KiB
    31 downloads
    Matshita CR-583 8x IDE CD-ROM Drive Firmware v1.07
Reply 7 of 8, by Horun
jasa1063 wrote on 2023-05-25, 01:37:
thanks ! the person wanting it seems to have some other issues (Re: Firmware for Panasonic/ Matshita CR-583 8x IDE CD-ROM drive) maybe you can help if they respond back 😀
Reply 8 of 8, by jasa1063
Horun wrote on 2023-05-25, 02:29:
I will see what I can do, but I don't have the CD-ROM anymore. I gave it to a friend for one of their retro projects. The biggest issue I had with this drive in a couple of systems was that it did not play nice with some Socket 7 boards IDE controllers in Windows 98SE. Plus I could never get the firmware update to work either. It was stuck at 1.05 and would not update.
