First post, by vorob
Sooo... Long story short, I've got Toshiba 5205-705 with bay expansion that have TV tuner. Laptop was sold with Win XP MCE and tuner works there without a problem, but now I've got usual xp pro sp3 and there are no MCE software, and other apps i was installing didn't help, they all got error that they cant get in touch with my tuner.
The attachment B4BEC66C-4557-43CF-86F4-D8F9958909A2.jpeg is no longer available
Since i've got no documentation on this device, maybe you can also enlighten me what these ports are for?
Thanks!
Reply 1 of 6, by adalbert
I would guess that the left one is TV antenna input, and the right one is video capture input. There should be some minijack adapters which can breakout these ports to antenna and RCA connectors.
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
Reply 2 of 6, by vorob
adalbert wrote on 2021-06-05, 22:33:
Yeee... I was able to find the manual and you are right,
The attachment photo_2021-06-06_01-16-11.jpg is no longer available
But this 2.5mm port is quite uncommon as I see in google...
Reply 3 of 6, by adalbert
vorob wrote on 2021-06-05, 22:50:
You could buy 2.5mm headphone adapter or something like that, cut it and solder some wires. But... you wouldn't be able to receive any TV anyway now? (but it might work for old game consoles and microcomputers I guess)
Reply 4 of 6, by vorob
Exactly 😀 I'll try SNES tomorrow. But I still search for software that can work with it. And for test I'll keep MCE as second OS
Reply 5 of 6, by BitWrangler
Random newsgroup post which had to be dug out of googles cache (And I don't know how long/if those links are any good to post)
""Jay Kapur [MSFT]18 years ago
The Toshiba is equipped witht the eMuzed Bali USB PVR,
which uses a Broadcom hardware MPEG2 encoder.""
Reply 6 of 6, by adalbert
You can try VirtualDub or VirtualDubMod software. Or DScaler http://deinterlace.sourceforge.net/ (DScaler is meant specific for analog video capture, i think it also can interface directly with the hardware?)
I think I used them for both PCI and USB video capture, but that was long time ago.
