First post, by gow75
new to using D-FEND reloaded but understanding it every day. i started with this link for repository REMOVED and or this one as well REMOVED only one i came across on a search. however when i go to install a game like say Dukenukem it fails in saying The Download of Duke%20Nukem%201.zip failed .. i put the source link and it updated the index of games/files but can not install anything. are there new REPO links?
would like to make a D-Fend front end on my windows 10 box for easy game playable , or is there an easier way to manage all the DOS games in one program what are recommendations?
also when i try to load any DOS games from my saved dos games folder i have will not load in drag or drop or import. where to get DOS games pack that works. thanks..
Reply 2 of 3, by gow75
Thanks , is there a pre configured XML file that can be loaded in DGgl to load all games into the list>? with out having to do one at time.
Reply 3 of 3, by gow75
DosFreak wrote on 2021-06-15, 22:05:
So called "abandonware" is not supported here.
You can use DBGL for freeware, shareware, demos or your purchased games:
https://dbgl.org/
can you provide more info on how to setup this front end, adding games etc. is there a TUT ?
