First post, by treeman
I had a power surge and it killed my 3dfx monster along with a s3 virge, also my kvm switch and monitor. The motherboard and rest of the system survived.
Anyway none of the dead parts show any physical signs of damage which makes it so hard to figure out if its salvageable.
I know there is alot of knowledge here with 3dfx repairs, where would I start diagnosing? I did some random multimeter readings looking for shorts and ground, shorts on the chipset and they look ok, for a quick scan not knowing every single ground pin.
What are the first and easiest things to diagnose, check voltages, resistance etc?
Reply 2 of 29, by treeman
I have a identical 3d monster that works so today I did a quick comparison side by side.
What really sticks out is the resistance from the output and input vga port pins to ground.
So on my working card I get alot of pins that show .500 resistance to ground, on the faulty one it shows .50 .. this is a big difference almost like something is nearly shorted to ground on that line.
Without a schematic (not like anybody has it) for a 3dfx its a guessing game where the line goes or can't even see anything burned.
Some of the port pins are connected to the
p15c3384q chip on the back, has anybody got any experience here or what would most likely get shorted out here first?
Talking about the area between C16 and R36
and u can see those traces go to vga out
Reply 3 of 29, by Eep386
Using a multimeter, test pins 12 and 24 of the P15C3384 10-bit 2-port bus switch chip there.
If they are shorted, then try removing the chip and re-testing the pads for pins 12 and 24. If they're still shorted, the fault is elsewhere (and you can put the chip back in). On the other hand, if the short is cleared, the P15C3384 is probably the problem chip.
Reply 4 of 29, by treeman
Pin 12 is short along with many pins between 1 and 12. Also I found shorts on one of the main chips on the front
I got shorts on cvdd and dvdd which are clock power inputs according to the pinout.
I guess from here it comes down to removing part by part to see if it clears the short and the bus switch is smaller and easier to take off.
I could probably keep turning it on and see what gets hot but don't know if its worth stressing it out more.
I will take off the bus switch when I have some time.
Reply 5 of 29, by Eep386
CVDD and DVDD are often connected together I think?
Reply 6 of 29, by treeman
I took off the bus switch chip, now the resistance on cvdd is .450~ looks much better! it is .350~ on the working card but with the bus switch naturally it won't be exactly same.
Now the big challenge will be finding a replacement
Reply 7 of 29, by maxtherabbit
strictly speaking you don't have to have the switch - you could bridge the Voodoo's DAC directly to the output DE-15 and just not use the passthrough
then handle switching externally with an Extron VSW 2VGA A
Reply 8 of 29, by treeman
If I had that hardware would be a good test to see if it works with the chip off. I have ordered the chip from ali express for about 3usd so now it will take a few weeks
Reply 9 of 29, by wiretap
Good luck. It's pretty hard to find legitimate/working chips on Aliexpress. I don't even order from there anymore because I've received too many fakes or factory 2nds with broken functionality. If the chip doesn't work, look for a used board that has the same one and transplant it.
Circuit Board Repair Manuals
My Project List
Reply 10 of 29, by treeman
for 3usd its worth the gamble but I am of the same opinion.
I don't have any other broken 3dfx, anybody have any idea on what other old cards or electronics I could find this chip?
Reply 11 of 29, by weedeewee
wiretap wrote on 2021-06-24, 12:46:
YMMV
I ordered an SMC FDC37c932FR and a winbond w89c982af. Both are working fine. My mainboard's keyboard&mouse are working fine again, as well as my 10Mbit HUB :-p
on the other hand, I ordered some MPF102 transistor, which don't match the datasheet pinout.
edit: just to add the correct chipid is PI5C3384q , not 15. This way google will find it 😉
Reply 12 of 29, by maxtherabbit
treeman wrote on 2021-06-24, 09:43:
you don't need a switch to test it, just manually move the monitor cable after the game switches to glide mode
it certainly won't work with the chip simply removed though, you will have to bodge over the signals
Reply 13 of 29, by weedeewee
maxtherabbit wrote on 2021-06-24, 15:15:
or just attach a second monitor to the card, just for the 3d output. right? easier than switching over, though still requires bodging the signals.
Reply 14 of 29, by treeman
weedeewee wrote on 2021-06-24, 18:38:
Yeah this is a great idea, so simple and logical!
Just tried it but got no signal 🙁
However the card is detected by the system so it is not totally dead.
This is what I did:
1. start system with video connected to 2d card (s3 trio)
test 1
2. boot to dos
3. start shadow warrior 3dfx patch
4. turn off power to monitor
5. switch cable from s3 trio to 3d monster
6. turn on monitor, no signal
7. when press keyboard can hear the sounds for the menu moving.
Test 2
1. take out 3d monster, only 2d card in system
2. start system in dos
3. start shadow warrior with 3dfx patch
4. error no card detected
Test 3
1. put 3d monster back in
2. connect vga to 2d card (s3 trio)
3. start Windows 98
4. check device manager and shows 3d monster works ok
After the tests I took out the 3d monster the 3 main chips were warm, not hot so I think this is a good sign.
I guess it looks like somewhere along the path the 3d signal is not going out to vga port, hope its not the main chip 🙁
Any tips what I can test next?
I will keep the switch chip off now, I did have shorts with it so it is still questionable
Reply 15 of 29, by maxtherabbit
Again, it's not going to work with the switching chip simply removed. You have to manually solder wires from the DAC input side of the switch ship's footprint to the connector output side
Reply 16 of 29, by treeman
I see, I do remember now reading that at the very start but got excited and jumped the gun.
Its not straight pin to pin connection from input to output? (where chip was) That would be too easy?
Reply 17 of 29, by maxtherabbit
treeman wrote on 2021-06-25, 02:02:
Bro I don't think you're picking up what I'm putting down. You might be better off just getting a new chip and installing it. Just randomly connecting pads to other pads is a good way to smoke something
Reply 18 of 29, by darry
maxtherabbit wrote on 2021-06-25, 02:37:
That and checking (and likely fixing) the potentially broken traces, if you do replace the chip .
As mentioned by maxtherabbit, do no connect the chip pads together. The missing chip was not a passthrough resistor block .
Reply 19 of 29, by treeman
I know what your saying, the input side of the switch needs to connect to the output side to the vga out, just like the chip would switch that output - for the 3d.
Ofcourse there will be a vcc pin and if connected to the wrong pin it will smoke it.
So I have no idea at this stage which input goes to what output. I can probably use a multimeter to try determine this on my working 3d monster, unless somebody already mapped this or knows? This is what I was trying to imply
