Reply 40 of 42, by BloodyCactus
I just looked on my dosbox, my 475 size com uses 0kb, its using 0x12 paragraphs, so just over 256 bytes..
35.66 KiB
ok I realised what your seeing, the line 136 should be
mov dx,setup_isr ;; already aligned correctly for tsr
shr dx,1
shr dx,1
shr dx,1
shr dx,1
I checked my original, yeah copy pasta error from hacking my uansi driver up for you. if you have umb its fine 😀
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 41 of 42, by Peter Swinkels
Okay, I will patch the code once I have access to my own pc and check again. 😀
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 42 of 42, by Peter Swinkels
@bloodycactus:
I added the missing lines, it works as expected now.
