First post, by andreja6
I recently saw this listing on ebay after buying a Tandy 1000EX: https://www.ebay.ca/itm/253407215602?hash=ite … gAAAOSwRVJftD46
I can't afford an RGBi monitor at the moment, but this is at least close to my price range. I am very interested in getting a nice crisp VGA CRT monitor connected to it, which are still relatively cheaper (and which I have), but if these are crap, I might as well just try saving up for an RGBi monitor.
Has anyone had experiences with these?
I'd be very interested to hear how well they work.
Reply 1 of 3, by maxtherabbit
so those can actually be made into quite a capable scaler with custom firmware BUT they don't actually support TTL RGBI!!
yes, despite the name they do not handle CGA or EGA, only analog RGB
Reply 2 of 3, by zyga64
If you add necroware's MCE adapter https://github.com/necroware/mce-adapter it should work quite well !
There is also very interesting attempt (using Rapberry Pi) here MDA/CGA/EGA/VGA to HDMI using Raspberry Pi Zero
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 3 of 3, by maxtherabbit
zyga64 wrote on 2021-06-19, 06:45:
my man scorp really loves reinventing the wheel 🤣, this appears to be exactly the same as the GGLabs unit
this is what I would recommend
a far more elegant solution for using TTL RGB on modern displays than converting it to analogue, digitizing it with the GBS, scaling it, and converting it back to analogue
