First post, by aroneox
Building a Windows / 98 gaming rig.
Goals:
* Use gutted eMachines eTower 566 complete with infamous “Never Obsolete” sticker
* Stable video card that supports DVI, VGA and composite out
* Play Doom, Quake, Quake II, Blade Runner, Zork (and other text adventures).
* Pentium III
* SSD hard drive
* Frugal budget
I’ve been collecting miscellaneous parts for this build over the last several months. Here is what I have so far:
* eMachines “Never Obsolete” tower case
* ASUS P2B-F Intel Slot 1 440BX motherboard — rev. 1.0, but has updated voltage regulator chip that should handle Coppermine P-III
* Pentium II 450mhz slot-1 processor
* 512mb PC100 ram (4x128mb)
* Enermax EG301P-VB 350 watt Power Supply
* Chaintec GeForce FX 5200 128mb AGP (DVI, VGA, “TV Out”)
* VisionTek ATI Radeon 7000 64mb AGP (VTKRAD7K64)
* Aopen(?) Cobra AW850 PCI Soundcard (w/ case-slot breakout connector board)
Up front, I’m mostly an old school Mac guy. I’ve built a couple white box PCs in the K6-2/3 and early Athlon era (Windows 2000), and have done a ton of PC maintenance in office environments. But I wasn’t in the DOS or early Windows scene when they were happening, so my knowledge there is really lacking.
Acquiring the eMachines Tower is what really got this project started. For me it’s the lynch pin for this build. Having it for the lulz is very much part of the fun in this project.
I know the eMachines Tower really doesn’t have the best ventilation. Because of that I’m obviously concerned about heat dissipation. My goal of P-III may be a non-starter because of that. And it may limit my graphics card options. I would rather have a stable and relatively quite system, and compromise on the retro-sleeper bragging rights of the processor and graphics card, as long as it can run my software goals well.
I would really like the graphics card to drive three monitors simultaneously: An LCD flat panel via DVI (for the OS), an SVGA capable Multisync CRT via VGA (for games), and a Tandy 9” green phosphor monochrome monitor via composite (for Zork).
Need some help discerning what graphics cards are compatible with the 2x AGP slot? Which graphics card capable of running the goal games well, and what will be the most stable (been reading that ATI drivers on Win 98 are flakey)?
Pentium III goal is more of a “I want a Pentium III because it was cool in the day” and it'd be cool to spec out a Slot-1 1.33ghz P-II, but it's not a necessity. Because this motherboard has an updated voltage regulator chip, I believe I can take advantage of the cooler running Coppermine P-III’s. So even if I’m not able to get the spec’d out 1.33ghz P-III, maybe there’s a nice compromise somewhere between heat output and performance.
Forego the P-III? Is the P-II 450 (coupled with the correct graphic card) plenty of horsepower for the goal games?
Recommendation for stable USB 2.0 card?
Recommendation for stable IDE to SATA adapter (using a 240gb Kingston SATA SSD)?
Gladly taking input on other things I may not have thought to ask.
Reply 1 of 21, by chinny22
Well if Stability is your main goal the motherboard is a very good choice.
Your graphics card is already a very good choice For those games I don't think you'll see any benefit from upgrading.
However if you just want upgrade to get that warm happy feeling then that's fair enough.
A GeForce 4Ti or high end FX cards would be the top level cards you could go. CPU will become your bottleneck but it does allow you to enable driver enhancements like AA, AF, etc
As you say ATI cards are less desirable due to dropping backwards compatibility.
I think pure dos the FX will output to VGA and DVI by default. Later cards definitely did. So your CRT/LCD setup should work out of the box.
Not sure about composite, worst case this would enabling in windows but a P2/3 would have enough power to run such games from within a windows session.
Your PII should be enough for the games in your list, It could start to struggle on later games, Say Quake 3.
I find a P3 600 (My VRM isn't upgraded) plays all my 9x era games just fine and anything that struggles is getting into XP era anyway.
Getting a 1GHz+ cpu will probably get 1 or 2 more years out of the rig. Think something like GTA3
Personally I recommend networking over USB for file transfers but if you really want USB 2.0 NEC based cards are what you want.
Any IDE to (CF, SD, SSD) I always recommend finding one that has a primary/slave jumper. I've had better luck with adapters that have the jumper over ones that don't.
Case cooling, I would just see how it goes. It's a period correct setup so you may be ok. It may just need a fan somewhere to encourage airflow. Just monitor and see what you think as a first step.
Reply 2 of 21, by aroneox
Thanks. I lucked into the motherboard at a yard sale.
I did a dry run with the mobo, ram and graphics card. Got it to POST without issue. Turns out the processor is actually a P-III 450 and NOT a P-II as was told to me by the original owner.
Have you had any experience with Slot-1 / Socket 370 "slocket" adapters. Seems opinions are varied on setup and reliability. But getting a 1ghz Coppermine socket 370 is WAY cheaper than slot-1 of the same speed.
You think it best to get a dedicated card both Win 98 and a separate one for DOS? Currently I don't have any inclination toward most DOS software, but that may change in the future.
I was thinking this Monoprice CF / IDE adapter. I like that it has convenient case-slot mounting. Also has jumper settings for primary / slave drive. I would then add a SD / CF card adapter to use in it.
https://www.monoprice.com/product?p_id=2785
As for the USB 2.0 card, I found these. They all look to be NEC chip based:
https://www.ebay.com/itm/233573461623
https://www.ebay.com/itm/233520825359
https://www.ebay.com/itm/124658545585
Reply 3 of 21, by chinny22
I don't have much experience with slocket adapters myself, I like the looks of the cartridge style CPU's but think for the most part you should be ok.
Think the major problems people run into it voltage support but you say our ok in that regard and bios support.
P2B does support Coppermine but you'll need to update bios to either 1013A or 1014.003 Beta
https://www.asus.com/supportonly/P2B-F/HelpDesk_BIOS/
Doom, Quake and some of the Zork games are Dos but if your just getting a feel for the hobby and more focused on Windows games you can get something like a SBLive or Audigy or Aural Vortex card which is more aimed at the Windows side of gaming but does give some basic dos support.
If you find yourself becoming more interested in dos or the above cards don't live up to your expectations you can always get an ISA card for dos later down the track.
Personally I keep CF/SD cards for dos only pc's but others seem happy with this same setup. IDE to CF to SD seems a bit overly complicated.
It may be better just getting a IDE to SD? Not really sure I've never used SD.
All those USB cards are fine
Reply 4 of 21, by PARKE
aroneox wrote on 2021-06-24, 07:54:
In principle they work fine. Two of my retro's are permanently dressed up with slotkets; one with PIII 1.0Ghz/100 and another with 1100/100 Celeron. I would prefer original slot 1 but they are hard to find - if you can score an 800/100 or 850/100 in your neighbourhood I would go for that solution.
Take note that the majority of slotkets on offer on Ebay are only supporting Mendocino Celerons and do not work with Coppermines without hardware modification. The date codes on the rear are a good indication; the ones dated later than 1999 are usually ok.
16.34 KiB
Good slotkets are, btw, not really cheap anymore these days and neither are the socket 370 PIII 1.0GHz or 1.1GHz cpu's.
Also take note that you need a proper heatsink+fan for the high-end Coppermines because of their TDP's around or over 30w.
Reply 5 of 21, by AlexZ
There is surplus of PIII CPUs as motherboards break down while CPUs last forever. So you may be able to upgrade very cheap if you keep looking. Still it looks like a good rig.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 6 of 21, by waterbeesje
That is a pretty stable base for a battle station.
Do you mind overclocking? Because the P2B is capable of running the fsb at 133MHz without any problem. If I remember the P2B series also support the 1/4 PCI divider.
My P3B-f (also 450BX) runs with a 933MHz CPU at a fsb of 140, stable and fast. So any 133MHz coppermine should be ok. Besides, the real world difference between a 866 and 1000 MHz isn't that big.
For the slotket I use a cheap ass "370cpu" named one, and I've had no trouble at all. I've posted it with a big socket A sink to ensure the heat can be handled when oc'ing.
The AGP bus speed will be oc'd to 89MHz, but don't be afraid of that. None of my geforce based graphics cards had any problem with that: from the gf2 mx400 to the Ti4200 and Gf4 mx440. (Forget ATI there). Just make sure the graphics card does AGP 2x ofc.
For AGP that's another limit: current. I'm not sure what's the limit, but there might be a chance top end fx series draw to much. Can anybody reject or confirm this? At least I know the Ti 4x00 won't be a problem 😀
Stuck at 10MHz...
Reply 7 of 21, by BitWrangler
waterbeesje wrote on 2021-06-24, 22:36:
Think I've got one of them kicking around. So that one does coppermines, good to know.
Reply 8 of 21, by aroneox
chinny22 wrote on 2021-06-24, 09:44:
...update bios to either 1013A or 1014.003 Beta https://www.asus.com/supportonly/P2B-F/HelpDesk_BIOS/ […]
...If you find yourself becoming more interested in dos or the above cards don't live up to your expectations you can always get an ISA card for dos later down the track.
Thanks for the BIOS link. Grabbed it, the flash utility and the Mobo drivers for Win 98.
If I go deep into DOS on this machine, I may source out a couple more hardcore cards that play better. Is nice to have those ISA slots available for that.
I agree it's a bit complicated with the IDE > CF > SD. But I haven't been able to find a case-slot mounting IDE/SD direct card. I would prefer a more direct solution, to make any troubleshooting easier.
And I'll pull the trigger on one of those USB cards now.
PARKE wrote on 2021-06-24, 10:57:
If you can score an 800/100 or 850/100 in your neighbourhood I would go for that solution. Take note that the majority of slotke […]
Take note that the majority of slotkets on offer on Ebay are only supporting Mendocino Celerons ...ones dated later than 1999 are usually ok.
Thanks for the good info. I'll keep that in mind with the slocket if I go that route. I don't think you're wrong about a 800 or 850 / 100. That would probably be a more realistic choice from a heat dissipation perspective.
AlexZ wrote on 2021-06-24, 21:25:
Yeah, with the current P-III 450 in play and the use case as it stand right now. I think I can wait out for the right CPU and the right price.
That is a pretty stable base for a battle station. […]
Thanks for the confirmation.
I'm not at all against overclocking. As chinny22 pointed out, with the BIOS update I would be set to explore that option. Some of the reading I've done seems to confirm what your putting forward about voltage and dividers.
I do think the slot-1 feels more like the posh version of the processor, compared to the to the slocket, which has a little bit of "I hacked this together" vibe for me in this particular build.
Part of the attraction for me with this project is the lulz factor (which started with the case & its sticker). To have ironic bragging rights about a 1ghz slot-1 P-III in this budget eMachines case, is sort of like jamming a monster V8 engine into a Ford Escort. There's no real world application that I can think of (especially in retro) for Win 98 and a 1ghz P-III , but it would be fun to know it's in there.
That said, this IS a budget build. Right now, I'm floating around the $25 mark on all the parts I've gathered up so far. Regardless of how silly it would be to have the 1ghz P-III big-boy slot-1 being under utilized in this build, real world finances, and potentially more important, real world heat dissipation may force that choice to be otherwise.
But I'm always open to options.
And I do appreciate the confirmation on graphics cards.
Reply 9 of 21, by PARKE
BitWrangler wrote on 2021-06-25, 00:44:
Here some documentation:
Evercool.pdf
70.95 KiB
49 downloads
and:
http://www.oocities.org/_lunchbox/articles.html
Reply 10 of 21, by BitWrangler
PARKE wrote on 2021-06-25, 11:06:
Here some documentation: Evercool.pdf […]
Evercool.pdf
and:
Awesome, thank you very much.
Reply 11 of 21, by PARKE
aroneox wrote on 2021-06-25, 05:33:
Not to mention the powerdraw that the high-end PIII's throw at the VRM.
Also keep in mind that you have to invest in PC133 RAM when you go for an fsb 133 cpu.
Reply 12 of 21, by aroneox
PARKE wrote on 2021-06-25, 14:40:
Ah. Yes. Also, didn't even remember about having to get correct spec ram when jumping to fsb133.
Even though PC133 is relatively cheap, I know I've got 512mb of WORKING PC100 on board right now. It seems getting working ram is often a crap shoot. I think this confirms the direction on this build for me.
Now the search for the right 800/100 or 850/100 P-III begins.
Reply 13 of 21, by PARKE
You have a very nice motherboard there (especially because it seems to be a Pentium III upgrade version - the first version was dedicated to Pentium II) and many people here, including myself, would choose to take it to the max just for the heck of it. But there are some considerations and there is a price tag involved.
Just out of curiosity, what is the type/number indication on the clock generator chip ?
31.02 KiB
Reply 16 of 21, by eric1992
I use SD cards for my Windows 98 SE PC so that I can have one SD card dedicated for Windows games from the 90s and another for DOS games (which has 98 on it as well). Windows 98 SE as far as I know is unable to have partitions above 137 GB, just so you know.
As for the sound card, you should consider looking for an ISA sound card, such as a Soundblaster 16 (I have a SB16 Vibra but I also have a PCI Soundblaster 128 in there too).
Your processor might be a bottleneck for the graphics card; does the motherboard support pentium III processors? I'm not too familiar with how bad of a bottleneck some processors can be.
Lastly, I flashed my slot 1 motherboard to the latest BIOS for that board, which I recommend doing.
Reply 17 of 21, by shamino
Your current Katmai 450MHz CPU already draws more power than most Coppermines. If you don't need a ton of speed then a P3-600E is a good option for a system like this, in fact it's pretty much ideal for cost and power/heat. They've always been cheap on eBay (haven't looked recently) and run very cool. Faster Coppermines in Slot-1 style are less common and quickly get much more expensive, so then you're more likely to have to fiddle with S370 adapters.
It's very likely to handle 133FSB but don't get too invested into that idea until you know it works. I've run into plenty of 440BX boards that couldn't pass tests beyond 124MHz or even 112MHz in one case (a P2B-D). A fair number of boards will max out at 133FSB in stress tests which I wouldn't qualify as reliable but technically you could say they ran it. I'd want to see at least 137MHz (+3%) in a test to call it reliable.
I believe the universal 133FSB overclockability of BX boards was exaggerated on the internet back then, though it became increasingly accurate as the chips and boards got revised. Back in those days not many people tested thoroughly when they overclocked, if the tools for doing so even existed yet, and crashes were always blamed on Win98 back then. It took a while after the popularization of WinXP for people to start trusting the OS and consider they could have faults in their hardware. By then the 440BX was a retired legend.
Despite how cynical I might sound though, I do love the 440BX at 133FSB. I ran 3 systems like that long term with no issues. It really is an awesome setup, but don't be too surprised if it has issues on a particular board.
I've had around 6-7 P2B-F v1.0 boards over the years. It's the only revision I've seen, actually. I think all but one of them had Coppermine VRMs. I think their production aligns more with P2B rev1.10 or so. I'm not sure the P2B-F was even available back when base P2B rev1.02 was being made because I haven't seen one whose date codes lines up with them.
Reply 18 of 21, by aroneox
PARKE wrote on 2021-06-29, 13:14:
Thanks. That is a proper chip for Coppermine 66/100/133 so you can always upgrade in the future.
👍 Thanks for the confirmation on that. Nice to know should I want to attempt a 133mhz jump in the future.
shamino wrote on 2021-06-29, 22:59:
...Despite how cynical I might sound though, I do love the 440BX at 133FSB. I ran 3 systems like that long term with no issues. It really is an awesome setup, but don't be too surprised if it has issues on a particular board.
Reading through the advice and experiences in this thread, I've decided that keeping the CPU at the 100mhz is best for one of my major goals in this project -- stability.
I think there could be some fun in tinkering with pumping it up to 133mhz, but I think that also has the potential to open a very wiggly can of troubleshooting worms. As it stands now, I've got a motherboard that is recognized at being very solid in its "stock" configuration, a good video card compatible with stock AGP bus speed, and known working memory. Changing the bus speed in pursuit of lulz and ironic bragging rights is a fun idea. But not only would I need to source new components to work with the increased bus speed, that would also add to the list of things when it comes to working through troubleshooting issues. And while I might be able to eventually sort those out, there's also the strong possibility that it might never be stable at the increased bus speed and I'd just end up back at the 100mhz anyway.
Looking over the Coppermine/100 slot-1 CPUs, the difference in TDP between the 600mhz and the 800mhz is a smidge over 1 watt. I think that pretty acceptable for the speed bump between the two. The 850mhz does take it up a noticeable notch in TDP at 25.7 watt. And if I were still pursuing the lulz for absolute bananas and completely unnecessary amount of speed in this build, it looks like the last native slot-1/100 is the 1000mhz which is 29 watts, and I imagine that would start to get a bit toasty.
The 800mhz I think would have plenty of headroom juice to take on whatever was the bleeding edge of Win 98 gaming in the era. And if I want to nerd out and run specs with someone who cares, 800mhz is still a very respectable speed for the era.
Reply 19 of 21, by chinny22
Yeh I don't get the point of overclocking anymore. I understand some people simply like the challenge and that's fine but the fact is you could simply get say a P4 based system for almost nothing and it'll be faster then even most extreme P3 overclock.
Stability is much more preferable in my book
