First post, by Rodney Betters
I'm trying to get F.E.A.R. working on my Windows XP rig and I've run into an issue. A number of lights throughout the game will flicker. As you approach the affected lights, they will either disappear, flicker for a moment, or flicker rapidly. The issue seems to occur when viewing the lights at certain angles or from certain distances.
Here's an example:
https://youtu.be/27f_rsFD5NQ?t=42 - If you look at the far wall at approximately 0:43, you can see the lighting on the wall flicker as the camera passes through the window
This can be corrected using dgvoodoo2:
https://youtu.be/kdU32NuYdL8?t=62 - As you can see, the light does not flicker when using dgvoodoo2
Now I would love to use dgvoodoo2 but, unfortunately, I'm using Windows XP which, as far as I know, is not supported.
This issue appears to be very old. I've tested the game with a GeForce 8800GTX (released in 2006) and the same flickering lighting problem occurs.
Is there any way to correct this on Windows XP?
I was poking around and found a program called 3D-Analyze which looks promising. Problem is, I have no idea which of the myriad settings might actually help.
57.26 KiB
Any suggestions?
Reply 1 of 9, by BEEN_Nath_58
Rodney Betters wrote on 2021-06-25, 00:24:
I'm trying to get F.E.A.R. working on my Windows XP rig and I've run into an issue. A number of lights throughout the game will […]
Here's an example:
Any suggestions?
3D Analyzer is a software solution, it won't give you much in regards to HW accelerated graphics. I am aware of this problem and personally use dgVoodoo2, however if this issue was widespread back then (2011 era) and if the game had good support, someone might have made a patch. Browsing through other forums, some have suggested to turn off V-sync while others have reverted to oldest drivers available, and another community upgraded their version of Windows(they didn't post their results). I am afraid I don't have any more information on this.
Reply 2 of 9, by Rodney Betters
Turning off v-sync does correct it in some cases but not all. I'm considering playing F.E.A.R. on Windows 7 so I can use dgvoodoo2. The only thing keeping me from doing so was my desire to use hardware accelerated sound (using an Audigy 2 ZS). How's the sound quality with ALchemy?
Reply 4 of 9, by BEEN_Nath_58
It should be good but sometimes things go wrong with hardware and drivers. Also you need a bit of luck to achieve everything perfectly.
Reply 6 of 9, by Rodney Betters
One last question for you guys: if I have EAX Advanced HD enabled, does EAX 2 also need to be enabled? or should that be turned off when EAX Advanced HD is used? I'm a bit confused about this because I was under the impression that EAX Advanced HD is just another name for EAX 4.
Reply 7 of 9, by Rodney Betters
So I've got everything installed but... I have no idea how to actually use dgvoodoo2... I put the d3d9.dll into the game directory but now I have no idea what to do. I tried a few different settings in the DirectX tab but performance and visuals just end up worse.
Reply 8 of 9, by BEEN_Nath_58
Rodney Betters wrote on 2021-06-25, 21:42:
Iirc advanced hd is different from eax 2, so you don't need to enable 2.0 if you use advanced hd.
Reply 9 of 9, by BEEN_Nath_58
Rodney Betters wrote on 2021-06-26, 05:01:
Just don't change anything if you don't face any issue with dgVoodoo2. If you face issue, try setting the last card from the List
