First post, by Scythifuge
Greetings,
I have an RCA made CF reader that connects to a PC parallel port with a keyboard pass through. The Windows driver setup refers to it as a Lyra. The part number is PC2200P. It has a logo titled "Shuttle Connects" on the back.
Is there a way with a driver or program that will allow me to see CF cards in MS-DOS 7 and/or Windows For Workgroups 3.11?
Thanks!
Scythifuge
Reply 1 of 1, by Scythifuge
I found a file, Mdcfe-sr.zip, and it has a DOS folder and a WIN folder, and the WIN folder contains the drivers that came with my CF reader. I tried running load.bat, and it works for some cards. While I can use 128GB cards under Windows 98 with the reader, it locks up with the DOS drivers. A 2GB card worked, so now I have to test the size limitation with various cards and shutdown/power-ons. Trying to read an unsupported card locks up the device requiring either a shutdown/power-on, or unplugging the keyboard passthru.
