First post, by rick12373
Does anybody know how to replace the CMOS battery on a Compaq Presario CDS 520? See the attached picture. It won't budge and I don't want to use too much force and damage it.
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 12, by snufkin
Looks like it might be something like this:
https://uk.farnell.com/panasonic-electronic-c … 2330/dp/1298256
In which case, I think it's spot welded to the carrier, so you'll probably have to unsolder the current one. Or maybe just cut the current battery out, then solder a normal battery holder in its place.
Reply 2 of 12, by rick12373
snufkin wrote on 2021-06-29, 21:03:
So I need to heat up the top part that is holding the battery down,remove the battery, put a new battery in and then add a small amount of solder between the top holder and new battery? Something like that anyway?
SB 16 Value CT2770
Reply 3 of 12, by snufkin
rick12373 wrote on 2021-06-29, 21:13:
If it's a spot weld then heating it won't work. I think welding is used because it actually heats the parts less due to shorter contact time. If you've got a reasonable soldering iron then I'd try unsoldering the battery from the PCB. Could be tricky as it'll be connected to at least the ground plane of the motherboard, which sucks heat away. Might be easier (though it'll look messy) to snip the battery off, then solder some wires between the remaining stubs and a cr2032 holder.
Reply 4 of 12, by rick12373
Sounds like cutting the old one out and adding one of these might be the best option. Not sure why it has space for 2 batteries though.
https://www.amazon.com/LAMPVPATH-cr2032-Batte … 25002958&sr=8-6
SB 16 Value CT2770
Reply 5 of 12, by snufkin
rick12373 wrote on 2021-06-29, 21:45:
I think that puts 2 cells in series, so produces 6V, which you don't want. I can't just find a ready wired single cell holder, so I'd just look to get a PCB mount 2032 holder, then solder some wires between the holder and the motherboard. Make a note of which pins on the motherboard are +ve. Cover the exposed pins with heat shrink tube or some tape, then some double sided tape or glue to fix the holder in place somewhere safe.
Reply 6 of 12, by rick12373
snufkin wrote on 2021-06-29, 21:54:
Yeah the two cells is strange, although on that listing it shows the thing connected to what looks like a motherboard.
SB 16 Value CT2770
Reply 7 of 12, by rick12373
I suppose this would work https://www.amazon.com/CR2032-Button-Battery- … 5003805&sr=8-13 .
If you get the black one it should be easy to see which wire is the +.
SB 16 Value CT2770
Reply 8 of 12, by PC Hoarder Patrol
Why not just use the proper pin header marked Battery / J11 for the external battery replacement pack, or make your own if you can't find it or an equivalent- saves any board-level soldering
The attachment Presario 500.jpg is no longer available
Reply 9 of 12, by snufkin
Ah. Yes. That makes more sense. You mean just plugging something like this: https://www.smallbattery.company.org.uk/sbc_840.htm on to the obvious header marked 'battery'? I was obsessing about changing the battery so didn't even notice that. I expect the motherboard has diodes to protect the existing cell from being charged. Do you think it would be a good idea to remove the existing battery anyway, in case it leaks?
Reply 10 of 12, by pampilhoso
snufkin wrote on 2021-06-30, 07:37:
I bought my external battery from that exact website 😀
In my case I left the original battery, but I might remove it later on by unsoldering.
The attachment 20210630_095634.jpg is no longer available
If you have FB and you are interested, please join https://www.facebook.com/groups/compaqpresariocds500series
You will have a lot of people that can help you with the Compaq CDS 5xx.
Reply 11 of 12, by rick12373
Ahh, awesome information. Thanks!
SB 16 Value CT2770
Reply 12 of 12, by BitWrangler
I'd just shrinkwrap 3 Energiser Lithium AAs and worry about it again in another couple of decades.
edit: though they don't seem as cheap as they were 5 years back when they were pushing them for digital cameras, or I got the pack on sale.
