First post, by Bitannihilator
I'm trying to track down an ISA IDE controller that will work with my 486DX2, but I'm having trouble finding out any info about drive support. My MB has a built in IDE controller but:
1-It doesn't support drives larger than 1024/16/63 (504mb)
2-it doesn't support CD-rom/ATAPI
3-the MB doesn't have VLB slots
I managed to get a caddy cd-rom connected to my SB Pro 2, so that is working but the hard drive is hard limited to 504mb. I tried flashing the XTIDE bios onto an expansion card, and it detects my 4GB HD fine, but OS/2 installation halts with a disk access error. Any suggestions on what to try next?
Reply 1 of 2, by Caluser2000
We can not help without you being more specific about your set up-make/model of system, OS/2 version would be a good start for instance.
I bet it does support ATAPTI cd readers as well. My DecPC 486 with OS/2 v3 Warp onboard vbl IDE controller certainly does. So does my AcerAcross 486DX2/50 system.
There will be updated installation disks for OS/2. The original disks in OS/3 v3 disks had very flakey IDE cd support wereas OS/2 v3 Warp Connect disks were far better at detecting ATAPI cd readers.
Reply 2 of 2, by Bitannihilator
The system itself is a Canon Innova 486e, it has what looks like an Acer v6 motherboard. I haven't been able to find too much about it at all. The BIOS has no options for anything other than fixed disks. I tried 5 or 6 different ATAPI drives, all tested good in my P2 system, and none are detected when I use a DOS 6.22 bootdisk with Oak cdrom drivers. My end goal is to install OS/2 W4, which worked with the CD-ROM on the SBPro and the original 400mb disk, and even this 4gb disk when partitioned to 500mb. When I add in the XTIDE bios on an add-in card the W4 installer halts with the hard disk error.
