386SX/40 build
First post, by jasa1063
I wanted to have a 386SX/40 in my retro PC collection, so I put together a system with the following specs:
TD70AN motherboard
AMD 386SX/40 CPU
IIT 387SX/40 Math Coprocessor
4MB memory 60ns (4 x 1MB 30-pin SIMMs)
MicroLabs Ultimate TrueColor ET4000AX 1MB ISA video card
Goldstar Prime2c multi I/O card
Sound Blaster 16 CT4170 sound card
3Com Etherlink III 3C509B Ethernet card
CompactFlash to IDE adapter with 2GB CompactFlash Card
ISA ROM card with XTIDE universal BIOS for disk handling
Everything was working fine except the system time would not update when powered off. It has a new barrel battery, so I was bit stumped. I found pictures of the same motherboard online and I noticed they all had the two middle pins of the 4-pin connected labeled CN7/EXT BAT jumpered. When I jumpered those two pins it is now keeps time just fine. There is no cache on this motherboard so the performance is solely based on the speed of the memory and the latency. I have this tweaked to the fastest settings the BIOS allowed. Here are a few benchmarks:
Norton SI 8.0: 29.2
3DBench 1.0: 10.7
Topbench 0.40a
Score: 65
Memory: 182
Effect addressing: 111
Opcode exercise: 102
Vid adapter speed : 326
3DGame opcode exercise: 84
The pictures are from the seller I bought the board from on eBay. Overall I am very happy with this build.
Reply 1 of 46, by BitWrangler
Nice, I had a similar board back in the day and I miss it.
Reply 4 of 46, by appiah4
That timebomb of a barrel battery right there..
Reply 5 of 46, by chinny22
Can you imagine what a 386 like that would have cost when new!
386 is bit old for gaming tastes but hardware wise I think they are quite interesting and would want to "fully spec" it like yours with sound, networking, etc
Reply 6 of 46, by appiah4
chinny22 wrote on 2021-07-05, 08:35:
I have a 386SX/25 all decked out with these goodies and it is the best 286 I ever owned.
Reply 8 of 46, by BitWrangler
Circa 1993, those boards with the sx40 were the cheapest combo on the market when the world was moving to 486, about $80 I think, when a 486SX25 and motherboard would be over $200. RAM was just about reasonable right then could put 4MB in it for $100, prior to epoxy factory fire. I/O card might have been $30, I'm not sure the gfx and sound were out quite when the board was new, but decent gfx and sound was $100 up. Probably you might have brought the whole caboodle in under $800, when 486s were still nearer $2k
The AMD 386 didn't have a very long market life due to being held up in court by Intel, so when they finally appeared, it seemed AMD more or less dumped them and prices tanked. Had that not happened though, Intel might have kept profit margins ridiculous and the early commercial WWW days would have been off to a very shaky and late start when you needed a $5000 box to get online instead of a $1000 one. Just saying that to point out that SX40 was never an expensive 386, a couple of years earlier the "only Intel made them" DX33 was stratospheric to most pockets though.
Reply 9 of 46, by appiah4
BitWrangler wrote on 2021-07-05, 12:01:
This is all true, I got my 486DX33 with a 1MB VLB GD542X (I forgot which model exactly) and an SB Pro for around $2200 in late 1993. 386SX/40 was something that was sold mostly to businesses at the time; gaming friends who were on a budget went for 386DXs and ISA SVGA cards instead, often AMD or Cyrix. I remember my neighbor having one of those and really struggling with Sim City 2000 once the population hit a certain level..
Reply 10 of 46, by AlexZ
386SX won't be able to take advantage of 4MB RAM unfortunately as later DOS games that would benefit from more memory also require faster CPU. It was my first computer, but I ended up upgrading to 386DX40 (from AMD, as prices went down). I eventually ended up with 8MB RAM. It could run popular 486 games of that era at slower but still playable speed - Settlers 2, Command & Conquer, Transport Tycoon. 386SX is mostly for the old classic 286-386 games.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 11 of 46, by Schule04
Simcity 2000 runs pretty badly even on lower end 486 systems
Reply 12 of 46, by Disruptor
A 386/40 should have some cache.
Regardless whether DX or SX.
Reply 13 of 46, by pentiumspeed
Not always.
Cheers,
Great Northern aka Canada.
Reply 14 of 46, by jasa1063
appiah4 wrote on 2021-07-05, 08:58:
That is how a view a 386sx system. Just like the 8088 was designed to make 16-bit computing a more affordable option, the 386sx was designed to do the same thing for 32-bit computing. You got everything a 286 offered plus all the features of a 386 at a lower price. To that end it certainly achieved it's goal.
Reply 15 of 46, by Caluser2000
Down our way I never saw any 386sx system above 25mhz. Most folk upgraded there current 386DXs to AMD40s of Cyrix 486DLCs. Or 486DLC systems sold as "486s. A lot of Cyrix chips were sold in mobos that would take 386 and proper 486 cpus. A The owners could upgrade them to proper 486s when prices dropped a bit. I have a system like that and have the original TI 486dlc33. And of course there was the early OEM 486SX25 plague with overdrive sockets in the early '90s 😉
Generally prices here were at least a grand higher here,sometimes more, then an equivalent system in the US reading magazines at that time.
Reply 16 of 46, by rmay635703
Disruptor wrote on 2021-07-05, 14:27:
With cache an sx40 would give an early ISA only 386dx-33 a run for it’s money
Heck IBMs 386SLC seemed to run circles around identically clocked 386DXs but it may have also coincided with the IBM having local bus IDE and VGA VRS ISA all around on the DX.
Reply 17 of 46, by BitWrangler
Some of these late SX chipsets had an 8KB cache built in, enough to cache 16MB.
Reply 18 of 46, by darry
rmay635703 wrote on 2021-07-05, 20:50:
AFAICR and assuming the WIKIpedia article is mostly accurate, these IBM 386LC and 486SLC chips had on-chip L1 cache, which surely helped .
Reply 19 of 46, by Caluser2000
In processing 16-bit instructions they wouldn't even come because it they do twice the processing compare to just one by 386DXs at the same clock speed. It'll be around the equivilent of a Harris 286/2o in that regard. That is one reason my first x86 system was a 286/16 instead of a 386SX16. I had done my research being to computers in general..😉 Folk go on about 32-bit instructions and Windows 3.x 386enhansed mode. The reality is Win3.1 is quicker in Standard mode.
So if anyone on vogons is a 286 basher and a 368SX fanboi at the same clock speed go and do some research before posting inaccurate information...😉 A 286 will steamroller a 386SX of the same clock speed processing 16-bit instructions.
