GATEWAY 9300 BIOS File
First post, by dwdrums321
Hello,
This is my first post.
Looking for a bios update file for a Gateway 9300
I have looked everywhere but cannot find it.
7507560.exe from driver guide does not work. (Device Components Are Not Supported!)
Anyone have a 9300 and happen to have the bios update file?
Thanks!
Reply 1 of 1, by PC Hoarder Patrol
dwdrums321 wrote on 2021-07-07, 04:51:
Hello, […]
Hello,
Thanks!
Welcome to Vogons 😀
Firstly, please note that the links below can provide filenames only - the actual file download links are dead, so you'll need to search the web for other sources like Driverguide.
Are you sure your chassis part number matches one of those listed for 7507560.exe (3500545, 3500546, 3500547, 3500571, 3500595). If it does and you're currrently on BIOS v16.03 or earlier then there are additional video update files you'll need as well.
If your chassis part number doesn't match, check this link for alternatives
https://web.archive.org/web/20010413093405if_ … able/9303.shtml
If you need any of the additional files you can get the filenames by following the links from the main file library page here
https://web.archive.org/web/20010212081533if_ … ble/index.shtml
