First post, by mike_canada
For those not aware, I'm getting closer to making Duke Nukem 3D (Dos) over today's internet a reality. and one emulated OS I want to test on is DOSBOX.
Right now I'm trying to make a script where a 3rd party program launches my script with a special file as a parameter which in turn runs DOSBOX. However I want my script to set the ultimate folder for the game but that's where I have difficulty.
This is my setup so far:
My script to launch DOSBOX:
#!/bin/bashfolder="/path/to/every/thing"if [ -z "$1" ]thenecho "file as parameter required"elseif [ -r "$1" ]thenecho "Preparing duke nukem...."echo 1 > /proc/sys/net/ipv4/ip_forwardkill -9 $(pidof socat) > /dev/nullkill -9 $(pidof slattach) > /dev/nullkill -9 $(pidof dosbox) > /dev/nullkillall socat > /dev/nullkillall slattach > /dev/nullkillall dosbox > /dev/nullsocat -4 PTY,link="/tmp/dbnet",raw,echo=0 TCP4-LISTEN:8001 &sleep 1slattach -L -s 115200 -p slip "/tmp/dbnet" &sleep 1ifconfig sl0 192.168.7.1 dstaddr 192.168.7.2 netmask 255.255.255.252 mtu 1500 txqueuelen 1500 up#iptables -t nat -Fiptables -t nat -A POSTROUTING -s 192.168.7.0/30 -j MASQUERADEdosbox -conf "$folder/dosbox.conf" -c "set DNU=$(cat $1)" -c "mount C: $folder"sleep 1kill -9 $(pidof slattach) > /dev/nullkill -9 $(pidof socat) > /dev/nullelseecho "Parameter needs to be a valid file"fifi
and this is the dosbox config file thats in the correct folder for its autoexec.bat
@echo off@echo Running Duke Nukem in DOSBOX networking style....C:ethersl -p 0x60 -h 3 0x2F8 1152000commit.com
In DOSBOX, when I run the SET command, the DNU variable value is correct, but dosbox wants to execute its autoexec.bat (shown above) before it mounts the C drive, but because the mount operation requires the working program folder and I want the working program folder only defined in the script itself (not in dosbox config file), I feel my only solution is to run all my commands as -c parameters when running DOSBOX, and that would be one heck of a long line to be passing to a command when I could do it in autoexec.bat?
The only kind of solution I could think of is throw all my other startup stuff in a separate batch file and try running that instead?
But is there a better solution? I want my setup to eventually work with as many OS's (including windows 10) as possible.
I added an attachment that shows my DOSBOX output:
