Tualatin in CUV4X-D
First post, by Sipha
Hi all,
I've recently picked up a machine with dual Coppermine Pentium III's in using an ASUS CUV4X-D motherboard. Would I be able to run Dual Tualatins in here with not much fuss as an upgrdade using the following adapter:
https://www.ebay.co.uk/itm/281238323137?ssPag … 353.m1438.l2649
Thanks
Simon.
Reply 1 of 2, by Sipha
Any ideas guys ?
Thanks
Reply 2 of 2, by BitWrangler
IF your board supports 1.5V and IF that's what the CPU is modded to, rather than the over specific 1.45 or so that coppermine boards don't understand, then there's a chance you'll get as far as your BIOS complaining about an unrecognized CPU. (Some will go "meh, it looks PIII-ish, we'll assume it is and boot.", some will go "it does not match the model name strings in my whitelist so I will assume it's a terrorist plot to blow me up, hence I will freeze and do nothing."
