First post, by SwissArmyTin
- Newbie
The AB BH6 I was planning on using for a build seems to have gone a bit south in the past...I knew the caps were from the plague and needed replacing, but I wasn't expecting the L11 inductor to be burnt to a crisp. When recapping the capacitors surrounding it, the inductor quite literally just fell off the board, revealing quite a nasty burn mark. My biggest problem is inductors and how they work are total voodoo magic to me, and I have no clue how to find what value L11 is/was to search for a replacement. The datasheet for this motherboard doesn't include any component specs and googling turns up zilch, so if anyone here knows, or has a similar motherboard and would be kind enough to measure it, I would be endlessly thankful.
Attached is a pic of where it originally was on the motherboard, and what's left of it now
Thanks!
