First post, by AlessandroB
I can take an IBM PC WITH 486DX4, THAT means voltage regulator... i see that i can install the intel POD, but what about AMD 5x86 or Cyrix 5x86? Chipset is OPTI 82c802
tnks
Reply 1 of 1, by Anonymous Coward
If your board accepts DX4s and has a VRM, it should be electrically compatible with both 5x86 CPUs, but whether or not those CPUs actually work may be up to your BIOS.
