First post, by elsegundo
So i have a Sony C1VN picturebook, im trying to install the driver for audio on windows 2000..i get the driver from the ftp..and its just a zipo extractor that spits out INF files..what am I supposed to do?
Ive tried the add hardware wizard and each time it fails to find any drivers, despite me linking it to the folder
What do I do?
Reply 1 of 29, by darry
elsegundo wrote on 2021-07-23, 01:10:
What do I do?
Are you sure the drivers you are trying to install are the right ones for your audio device ?
Are you sur those drivers are compatible with Windows 2000 ?
Can you share a link to those drivers ?
Can you post the card's PCI device ID for the card, you can use pcilist.exe : https://www.majorgeeks.com/files/details/pci_list.html ? Specifically, please post the equivalent of this screenshot for your card, it will include all required info (Vendor ID , Device ID , Susbsytem ID) :
The attachment pcilist_example.png is no longer available
Reply 2 of 29, by elsegundo
darry wrote on 2021-07-23, 01:21:
Are you sure the drivers you are trying to install are the right ones for your audio device ? […]
What do I do?
Ok well first off here's the link
http://dose.0wnz.at/ftp.vaio-link.com/PUB/VAIO/AUDIO/
downloaded ACD_YAM_613103152_2K since the last driver ending in 2k Worked with windows 2000..
Reply 3 of 29, by cyclone3d
Original file name for the installer should be:
YA512C2K.EXE
according to this page:
http://sonyvaiodriver.com/category/sony-vaio- … g-c1vn-drivers/
You really need to check the correct file name before trying to install anything from the FTP backup as there are going to be a bunch of different installers for different models.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 29, by darry
This is probably the file you need .
The attachment YA512C2K.EXE is no longer available
Having the PCIList info would allow confirming this .
Reply 5 of 29, by elsegundo
cyclone3d wrote on 2021-07-23, 01:39:
Original file name for the installer should be: YA512C2K.EXE according to this page: http://sonyvaiodriver.com/category/sony-vai […]
YA512C2K.EXE
unfortunately all the names are different compared w sonys archive
Reply 6 of 29, by cyclone3d
That is strange since the file names on that page should match with what is on the ftp backup.
The name of the one you originally downloaded looks like it is probably for the later AC97 only Yamaha chips.
YMF7x4 Guide
Reply 7 of 29, by elsegundo
darry wrote on 2021-07-23, 01:57:
YA512C2K.EXE
installed, nothing happened
heres the pci list data (had to switch to ME to get this)
Reply 8 of 29, by elsegundo
cyclone3d wrote on 2021-07-23, 02:22:
only ones i could find, the one just posted (YA512c2k) i couldnt find anywhere before it was posted here
Reply 9 of 29, by darry
Inside the INF file in that driver set , the line
%*WDM_DS1Native.DeviceDesc%=WDM_DS1Native, PCI\VEN_1073&DEV_0012&SUBSYS_80B0104D
seems to match your hardware .
Try unzipping the file attached and updating the driver from device manager while pointing to the directory created by the aforementioned unzipping .
The attachment YA512C2K_extracted.zip is no longer available
Reply 10 of 29, by elsegundo
darry wrote on 2021-07-23, 02:51:
Inside the INF file in that driver set , the line […]
Yes! the unzipped file works and i got sound!..now onto trying to install the other drivers
gonna see if i can hunt down the equivalents
Reply 11 of 29, by elsegundo
they dont match up at all
yeah bro, not a single driver there matches
if you guys know where to look id appreciate links
Reply 13 of 29, by cyclone3d
Ok, for the video driver try:
VCD_ATI_5021955036.EXE
I was one of the original downloaders of the FTP and I still have a full copy on my computer. You could also download the whole ftp from archive.org that I uploaded but it is huge.
YMF7x4 Guide
Reply 16 of 29, by darry
Some drivers I found :
The attachment SPI60W2K.EXE is no longer available
The attachment SOJ300KNA4.EXE is no longer available
The attachment CD51110.EXE is no longer available
Reply 17 of 29, by elsegundo
darry wrote on 2021-07-23, 05:06:
Some drivers I found : […]
SPI60W2K.EXE
SOJ300KNA4.EXE
CD51110.EXE
soj300 says wrong version great looks like ill need the bios up date in HAND and move my copy of windows 2000 to my C drive
Reply 18 of 29, by elsegundo
after installing pi I get this message "please insert disk labeled sonyPI:
Reply 19 of 29, by darry
elsegundo wrote on 2021-07-23, 05:25:
Try pointing it towards : c:\winnt\drivers\spi\
