First post, by SuperSawlver22
SuperSawlver22
Offline
So I have the 1997 Gizmos and Gadgets ISO mounted and it appears to at least load but I encounter a MIDI error (image attached). Dosbox tells me it must be run on Windows. Is there a driver or something I can install that will make the app see a midi driver? Currently mounted with virtual clone drive. Thanks for your help!
