First post, by TheMobRules
Hello
Recently I've got an XT clone PC in very good shape, almost mint, dating from around 1990-91. For the moment I've repurposed the case to house an early 386 from around the same era since I cannot use or test the XT motherboard: I have no RGB compatible monitors and none of my VGA cards seem to be XT-compatible.
I've built myself an AT2XT keyboard adapter and are in the process of building an RGBtoHDMI using a RaspberryPi Zero so I can use the video card that came with the computer, but it will be a while before I get the PCB and necessary parts. So in the meantime I'd like to find more about the card:
870.2 KiB
Mitsubishi WEAL10
It's made by Mitsubishi, model name seems to be "WEAL10", main chip is DC462312A and has 128KB of RAM and a 16KB ROM (attached). By the looks of it I assumed it's probably a monochrome adapter with a character ROM but was unable to find anything about the card of the chip, except for this thread in the VCF:
Help idetinfing 8 bit MITSUBISHI video card
The poster of that thread seems to have gotten it from an XT clone that looks identical to mine, but has no additional info. Some people there also suggested it may be an EGA clone due to the amount of memory, but then the original poster seems to have given up and the thread died (I hate when that happens).
Any details or suggestions are welcome, especially any clues as to what the DIP switches and jumpers on the card may be for!
    WEAL10.zip
    5.04 KiB
    50 downloads
    ROM
Reply 2 of 8, by kdr
TheMobRules wrote on 2021-07-25, 20:14:
I wouldn't be surprised if it is a combo MDA/Hercules/CGA card. Many of the monochrome monitors from the turbo XT era were dual frequency, and are able to sync to a 15.7khz CGA video signal. (And thanks to the awful CGA palette, a lot of games actually look better in 4 shades of amber/green than they do on an RGBI colour display!)
I don't see any executable code in the ROM dump so it isn't an EGA card.
There might be some driver utilities installed on the machine's fixed disk. I think these dual mono/CGA cards could usually switch modes via software, and the DIP switches just set the default mode to use during boot.
I would also suggest trying to source a 9-pin monochrome CRT. In my region they still show up from time to time and are practically free, unlike colour displays which are starting to become unobtanium.
Reply 3 of 8, by Predator99
What is the frequency of the X1 at the bottom left? Usualy there is
MDA 16.257 MHz
Hercules 16.000 Mhz
But indeed there is too much RAM for one of these cards.
You could try this to test the card 😉
6€ MCE2VGA replacement - CGA/EGA/HGC capture with logic analyzer
Reply 4 of 8, by TheMobRules
kdr wrote on 2021-07-25, 21:04:
Yeah, that's probably the case. I just noticed the DIP switches on the motherboard are set to the "CGA" position, and going by the speaker beeps it seems to POST correctly under that configuration. Still, I won't be able to confirm until I get a display.
Unfortunately the machine came only with this card, and a Multi IO card with serial, parallel, clock/battery and floppy controller. It seems to be quite a bare bones machine for 1990-1991, with a single 360K 5.25'' floppy drive.
I'll be on the lookout for old 9-pin monitors, in any case the RGBtoHDMI is cheap enough and supports MDA/CGA so hopefully it will work with this card.
Predator99 wrote on 2021-07-25, 21:30:
MDA 16.257 MHz
Hercules 16.000 Mhz
The oscillator is 16.000MHz, so I guess that would mean Hercules? What is the setting normally used in the DIP switch of the motherboards for Hercules cards? My motherboard only has MDA/CGA/EGA options, it was set to CGA when I got it.
Very interesting, didn't know about that! Also, I'm going to dump the motherboard BIOS and add an entry to your XT BIOS Collection thread 😉
Reply 5 of 8, by mkarcher
TheMobRules wrote on 2021-07-25, 21:47:
MDA 16.257 MHz
Hercules 16.000 Mhz
The 16.257MHz (original IBM MDA and EGA clock) and 16.000MHz (usual clone clock) are considered equivalent for video timings. The difference of around 1.6% doesn't matter for monitors being able to sync to it. As your card has 128K of RAM, it has enough RAM to support Hercules (you need 64K), CGA (you need 16K) and even some extended modes. So I guess given suitable DIP switch settings, the card might be Hercules compatible, but it still can be CGA compatible with other DIP switches. For CGA video, you need 14.31818MHz. You do not find an oscillator with that frequency on your card, but that doesn't tell you anything. This clock frequency is available on the ISA bus at the pin called "OSC", and the orgininal CGA card, and most CGA/Hercules combo clone cards, and even the original IBM EGA card (in CGA-compatible modes) take the 14.31818MHz clock from the ISA bus connector, so they don't have any oscillator for that frequency on the card.
TL;DR: Just because there is a Hercules compatible crystal oscillator on your card, that doesn't mean the card can't run in a CGA compatible mode producing CGA video timings.
Reply 6 of 8, by kdr
There isn't a Hercules setting. But a Hercules (or compatible) card also acts as an MDA for text mode.
The BIOS only has direct support for MDA and CGA cards (which is why these don't have their own video BIOS). The switches on an XT motherboard inform the BIOS where you want the default video output to go. The "EGA" option is actually the same as "no video card installed", which means that the system BIOS won't try to initialize any cards. That's because the EGA has its own video BIOS onboard.
Reply 7 of 8, by TheMobRules
I'm not thrilled about resurrecting my own thread, but with the help of an RGBtoHDMI I was able to test this card, and wanted to share my findings in order to give this some closure and to keep it for reference in case anyone else happens to find one of these cards.
As expected, this card is both monochrome/CGA compatible. The default settings seem to work fine for Hercules/MDA:
  • JP2 & JP3 set to 1-2
  • All DIP switches set to ON except for #8
In order to enable CGA mode, the following settings worked for me:
  • JP2 & JP3 set to 2-3 (this grounds pin 7 -mono video- and connects pin 3 -red-)
  • Set switch #1 to OFF
With the above settings, it displayed all CGA modes in CheckIt tests correctly. Not entirely sure what the other switches do (some seem to enable and control the parallel port I/O address which isn't even populated, so it's useless, and switch #4 needs to be ON or I'll get missing video card beep code).
Reply 8 of 8, by VileR
TheMobRules wrote on 2022-05-18, 18:01:
Perhaps there might be a switch that toggles between the normal (2-dot) and 'thin' (1-dot) fonts?
From your dump of the character ROM it appears to have both versions for CGA (8x8) as well as monochrome (9x14):
6.81 KiB
Totally boring factoid: the "thin" 8x8 font (second from left) is identical to the Sperry PC's on-board video charset. Which makes sense, since the Sperry PC was also manufactured by Mitsubishi.
