First post, by scottie4442
ok my setup works great in win98se, but when i reboot to dos I cannot get my midi output to go to the gameport midi interface. I have an audigy 2 zs setup according to the instructions i found on here, works fine in win98se and goes to the gameport midi and then my mt32-pi. when I reboot to dos it send the idi to the internal midi on the sb16 emulation. I checked the sbecfg and it shows that the mpu port is 330 which it is in win98se, I am using softmpu and when started it finds the mpu port but midi still goes to the internal sb16 midi emulation.
