First post, by mike_canada
I want to eventually create a setup where users can create a special configuration in windows and then it gets embedded onto an image then when dosbox loads, the image is loaded with the custom configuration. I want to use dosbox as my test bed then I want to move to other emulators to make my idea compatible with all emulators.
Here's how I plan my idea.
1. Have a base image already prepared.
2. Run a custom windows program that takes the image and appends custom configuration data to it.
3. Launch a dos emulator that treats the image as a bootable hard drive
4. When virtual hard drive boots, it reads certain sectors where the configuration lies.
Here's what I tried:
IBM/MS Interrupt 13 extensions (details of that int at http://www.ctyme.com/intr/rb-0706.htm)
I created a program that runs the extensions. The installation check passed, but getting extended disk info and trying to read data are both problemmatic. In fact, the disk info returned all zeros for cylinders, heads, and sectors which is wrong. For drive parameter it wanted anything from 80h to FFh. I tried 80h and 81h and I got no luck.
Are Interrupt 13 disk extensions supported by DOSBOX?
or what interrupts should I use that DOSBOX and many other DOS emulators will support to try to perform a direct disk data read?
And if you're thinking I should use file open functions, that won't work because then at the image creation end, I'll have to figure out how to inject the file into the image itself without causing filesystem corruption which I think would be a more difficult task.
Reply 1 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
INT 13h functions are supported for disk images, but the extensions you're looking at are not supported.
mike_canada wrote on 2021-07-26, 21:12:
Actually, that could be the easier thing to do. Rather than "inject" the file externally you would create it in advance. That way the file is stored at a known location within the image and you can externally modify the sector(s) that comprise it, allowing easy access with the DOS file open and read functions. If there is concern that the file can be of variable length, it should be possible to make the file as large as could ever be needed and simply mark the end of data with an EOF character or so, which is an old standard of DOS files.
Reply 2 of 6, by mike_canada
ripsaw8080 wrote on 2021-07-27, 13:55:
In that case, the interrupt call should have returned the carry flag being set instead of cleared when calling those extensions. But it didnt.
What about the basic INT 13 extensions such as Int 13h with AH=02h found here: http://www.ctyme.com/intr/rb-0607.htm
Can we work out some mathematical formula on this?
Perhaps I could make a giant base image, then inject the configuration into certain bytes of the image that equal valid file space and somehow update the FAT16 table so DOS recognizes the file as a valid uncorrupted file.
I make my images with mkfatimage16 (that comes with dosemu) emulator for Linux, and it sets the partition type to #4 (Fat 16 < 32MB)
Reply 3 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
mike_canada wrote on 2021-07-27, 21:53:
The carry flag IS set for unhandled functions of INT 13h, such as the function you inquired about; not sure how you came to a different conclusion.
That's an essential function of INT 13h, not really an "extension", so it is indeed supported.
Just search for the contents of the pre-created file within the image, then you know where it is located and can externally modify it in place. The directory entry and FAT chain for the pre-created file would already be established, no need to update them; you only need update the contents of the file.
Reply 4 of 6, by mr.cat
Well mtools also exists, no need to reinvent the wheel if you don't want to 😁
I've successfully used it for syslinux floppy images but it probably can be used for hd images just as well.
Reply 5 of 6, by mike_canada
mr.cat wrote on 2021-07-27, 23:41:
....except the target OS is 64-bit Windows (specifically Windows 10) But I have a 32-bit computer so I can only make 32-bit programs for that OS. I did use mtools for linux and its not bad for it.
Reply 6 of 6, by _Rob
dosbox-x should have more complete int13 support, if you want to give it a try.
