First post, by appiah4
- l33t++
I have a Biostar MB-8433UUD-A running an IBM Cx5x86-100 with Feiopa's UUD2014 BIOS.
The problem is that intermittently, and for no reason that I can understand, the computer fails to detect the DVD-ROM drive. What happens is that I boot DOS and the DVD-ROM driver semi-randomly complains about being able to find no optical devices whatsoever. I say semi-randomly because when I this happens, no amount of soft or cold booting will fix the issue. Sometimes cold booting and reseating the IDE cable on the DVD-ROM end seems to get it detected again, but not always. Sometimes going into the BIOS and fiddling with a few settings gets it detected, but it eventually comes back. Sometimes I just turn the computer off in frustration and the next morning when I boot it the DVD-ROM gets detected. Crazy.
The DVD-ROM was initially the secondary master with an 80 stripe Ultra-ATA cable, so I moved it to Primary Slave with a regular 40 stripe IDE cable and the behavior is the same. I have also replaced the DVD-ROM and the issue persists. IDE Primary Master is a CF-IDE adapter with a 2GB CF card which works flawlessly. At the time I was also experiencing some general system instability at 133MHz so I dialed down to 100MHz, which seemed to fix to issue. for a short while but it returned shortly after.
I know a lot of people are running this board in their systems so I was hoping someone might give me a few pointers? This does not seem to be a cable/drive issue, and while a DVD-ROM may be too new for a 486 board I doubt that is the root of the problem. I think there must be a BIOS setting that is causing the problem but I can't seem to find it. It's driving me crazy, as I want to get this system stable and make it my main DOS PC. Please help VOGONS, you are my only hope.
